454 engine noise
Old Jul 26, 2014 | 12:38 PM
Tumblershawn's Avatar
Tumblershawn
Default 454 engine noise
I know this is a longshot, but if you have a guess as to what this clacking sound might be.....
S
Old Jul 26, 2014 | 12:48 PM
jnb5101's Avatar
jnb5101
Hold a long screwdriver handle to your ear and touch several areas on the engine. Especially the valve covers. That will help locate the problem. I'm thinking a push rod has been dislodged from a rocker?
Old Jul 26, 2014 | 12:57 PM
Les's Avatar
Les
It's hard to tell through my cheap laptop speaker but it could be as simple as an exhaust leak.
Old Jul 26, 2014 | 02:02 PM
scottyp99's Avatar
scottyp99
Yeah, it seems to have that "putt-putt" sound of an exhaust leak. Take a piece of hose, put one end up to your ear, and hunt around with the other end, you will know when you find it if it's an exhaust leak.
Scott
Old Jul 26, 2014 | 06:53 PM
sullyman56's Avatar
sullyman56
http://youtu.be/mCKJqN6YbUk
S
Sounds like an exhaust leak to me too. Perhaps a bad header gasket?
Old Jul 26, 2014 | 08:19 PM
Tumblershawn
I tried the screwdriver trick, I didn't find any significant difference in nose or vibration at various points around block. The noise doesn't seem to change from cold to warm engine. Car seems to drive fine and make good power. I'll try the hose next, I like the idea of an exhaust leak, that sounds less catastrophic. As a matter of fact, the noise seems to be most auidible around the front drivers side. That's also the location of the bolt that goes through the alternator adjusting bracket, and through the manifold.... A bolt that I recently changed. There is about a 3/4" space between the bottom of the bracket and the top of the manifold. The PO hadn't put a block through the alt bracket, and I had been having problems with belts and pulleys, so I changed and put the bolt though the bracket into the manifold, but didn't put a spacer. This seems silly now..... I'll get out the hose to verify, but it appears the power of the forum has solved another crisis. Thanks all
S
To 454 engine noise
