c3 atenna removal
Aug 1, 2014 | 12:48 PM
c3 atenna removal
Hello
looking to put a car cover on my c3 in the garage and not sure how to remove the antenna. any help would be appreciated
newbie so forgive the stupid question
Aug 1, 2014 | 01:05 PM
Car covers usually come with a small patch to re-enforce a hole you can cut to put your antenna through.....no need to remove it. If, however, you want to remove the antenna, you get to it by removing the muffler first.
Aug 1, 2014 | 01:19 PM
ok thanks.....I figured I could just cut a hole for the antenna but wasn't sure.
thank you
Aug 1, 2014 | 01:28 PM
Cruise-In II Veteran
Loosen the top nut. Unscrew the antenna mast. Retighten the nut. Put your cover on.
At that point, mark the location for the hole if you want to slit the cover and iron on the reinforcements.
Aug 1, 2014 | 01:41 PM
Quote:
Originally Posted by
Easy Mike
Nice tip
Aug 1, 2014 | 01:54 PM
Hi,
I'm pretty sure just the nut needs to be unscrewed, then the mast pulls straight up.
Regards,
Alan
Aug 1, 2014 | 07:47 PM
Alan 71
Hi,
Regards,
Alan
You are correct. I was thinking of entire antenna removal, including cable.
Aug 2, 2014 | 09:34 AM
C3 Stroker
...I was thinking of entire antenna removal, including cable...
You're working too hard, Stroker.
Aug 6, 2014 | 12:01 PM
6th Gear
I installed a power antenna and works perfectly with car covers.
Aug 9, 2014 | 12:01 AM
I cut a hole in my cover !!!
Prob solved.
Aug 9, 2014 | 10:45 AM
Alan
I've seen magicians levitate pretty girls, but I've never seen an antenna mast levitate!
Aug 9, 2014 | 11:42 AM
Hi jnb,
I think there's almost always a hidden wire of some sort!
Regards,
Alan
