mystery vacuum line?...Help
Old Aug 2, 2014 | 10:10 AM
East Coast's Avatar
East Coast
Default mystery vacuum line?...Help
Hi guys, I found a disconnected vacuum line on my 69 and was wondering where it connects. Sorry for the poor pictures it's really hard to get a good shot so I placed a blue pen pointing at the line, it seems to come out of the firewall.
Old Aug 2, 2014 | 10:13 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Is it the line to the hot water control valve? Not sure how a 69 is set up.
Old Aug 2, 2014 | 10:29 AM
Alan 71's Avatar
Alan 71
Hi,
I believe it's the vacuum supply line that runs to the heater/defroster controller in the shifter console. It T's off the wiper door vacuum supply line
Regards,
Alan
This is a 71, I believe the T is in a slightly different place in 69.
Old Aug 2, 2014 | 10:39 AM
Dave J's Avatar
Dave J
Judging by the location next to the wiper door, and if it's next to two other vacuum lines, it is the wiper safety valve vent hose. If you take the wiper grill off, trace the hose and see if it goes to the valve.
If that is your guy, it is supposed to be vented to atmosphere.
Old Aug 2, 2014 | 10:51 AM
Alan 71's Avatar
Alan 71
Hi Dave,
If you look closely that hose has the grommet moulded as an integral part of the hose.
It doesn't push through a grommet as the hoses from the safety valve do.
It's also a smaller diameter and a different material than the vacuum hoses that are part of the wiper door system.
Regards,
Alan
You can see the 3 hoses from the safety valve and their large diameter grommet in this pic. (Again this is a 71.)
Old Aug 2, 2014 | 01:01 PM
East Coast's Avatar
East Coast
Hmm, can't seem to find the connection, every other T is connected, I will keep looking around!
Thanks Guys!
Old Aug 2, 2014 | 02:19 PM
Alan 71's Avatar
Alan 71
Hi EC,
I believe 69 cars have a large yellow striped vacuum supply hose that runs from the vacuum storage tank along the firewall behind the engine.
The T should be in that hose. It should have 2 large nipples and 1 small nipple. The small nipple is very easy to break off.
Regards,
Alan
Old Aug 2, 2014 | 02:44 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Originally Posted by Alan 71
Hi,
Regards,
Alan
Alan nailed it, that is exactly what it is.
Old Aug 2, 2014 | 03:50 PM
AkrHack's Avatar
AkrHack
Hi Dave,
Regards,
Alan
Thanks once again Alan as this solves yet another mystery for me. That hose identified in your picture that is to be vented to the atmosphere has an obviously owner installed plug in the on my '71. I'm wondering why it was plugged by a prior owner and what the blockage of that hose caused a) not work at all or b) not work properly. I hope it changes the behavior of my wiper door as it goes down so fast that it closes on my wipers and prevents them from parking.
Old Aug 2, 2014 | 05:24 PM
pws69's Avatar
pws69
Originally Posted by AkrHack
... I hope it changes the behavior of my wiper door as it goes down so fast that it closes on my wipers and prevents them from parking.
That is exactly what the "switch" that hose is connected to is supposed to PREVENT!! Definitely unplug it and if you still have the problem, then the the vacuum "switch" it is connected to may need adjustment or replacement.
Old Aug 2, 2014 | 06:35 PM
Dave J's Avatar
Dave J
I cannot hardly count how many Bubba'd safety valve vent tubes I've seen over the years that have been plugged. Bubba1, Bubba2, Bubba3 or whoever since these cars were new somewhere just absolutely had to put a screw (most common), golf tee, or whatever to plug them. After all, if there is a hole, shouldn't there be a connection or plug?
The real purpose of the open vent hose is to VENT the top cavity of the safety valve over the spring to try to prevent foreign material getting inside the valve when the plunger cycles. If you examine the 3 ports on the valve, only the bottom two are for any actuating function. The port closest to the white plunger is the vent.
If pulling the plug changes the behavior of your wiper door, you really have problems with how your hoses are connected. If your wiper door closes on your wipers, you have a defective relay, safety valve, or both.
If you want to know how to diagnose, let me know.
Old Aug 3, 2014 | 07:51 AM
AkrHack's Avatar
AkrHack
Dave J, you nailed it - my hose was plugged with a drywall screw! Anyway, I unplugged the hose and retried the wipers and the result was the same - the door closed on the wipers before they could park. If you know how to diagnose the root cause, I'm all ears.
Thanks,
Rick
Old Aug 3, 2014 | 11:50 AM
rgl201sm's Avatar
rgl201sm
Default Similar question regarding wiper door issues
Hello, I was reading this chain and I am having a very similar issue. My wiper door doesn't close. For a week or so it would be closed when the car was off. When I started it up, still closed. But if I accelerated heavily, it would open for just 2-3 seconds, and then it would close back up, and would be fine. It repeated this cycle for a week or two. Now it just stays open. Does this ring a bell for anyone? Note my headlights work perfectly, they open and close correctly via the headlight on/off switch, and also open properly if I pull the headlight override switch. So it seems to be isolated to the wiper door part of the system.
Thanks.
Ron
To mystery vacuum line?...Help
