Low Oil Pressure
Old Aug 2, 2014 | 02:59 PM
jskenter's Avatar
jskenter
Cruising
Default Low Oil Pressure
I have a 75 corvette stingray. just changed the oil in it. There are no oil leaks, it doesn't appear to be burning oil, but the pressure will not stay up. I will be driving it and it drops to 20 on the gauge. any ideas?
Old Aug 2, 2014 | 05:37 PM
DUB's Avatar
DUB
The pressure will not stay up WHEN??? At Idle, under a load...which is it???
Did you have this issue BEFORE you changed the oil???
How many miles on the engine????
A lot may be in the grade of oil you used..depending on the engine itself. May require different viscosity to compensate for bearing clearances that may be larger..due to age and wear. I do not know...so that is why I am asking. NOT every car uses 5w-30 or 10w-30 oil...some older aged, weathered engines may need an oil a bit heavier in viscosity.
I would verify this issue my installing another gauge and seeing if it reads the exact same. I would get a gauge that is NOT electric...but uses the tube to transfer the oil to the gauge ...like the earlier years had. If it reads differently...then it can possibly be in the sending unit. I have seen and experienced some crap or a sliver of RTV or something that plugs or partially blocks the opening of the sending unit.
Not knowing what you oil pressure is when you crank it up COLD...first thing in the morning....it is hard to tell.
DUB
Old Aug 2, 2014 | 05:40 PM
MMH2009's Avatar
MMH2009
Hows your gauge functioning?
Old Aug 2, 2014 | 09:40 PM
jskenter's Avatar
jskenter
Cruising
DUB
It is fine at the idle, but when I am on the highway, it drops. the temperature is fine, it just drops. It was functioning fine before the oil change, but I changed the oil because it was full of gasoline. is it the head gasket?
Old Aug 2, 2014 | 09:47 PM
Indiancreek's Avatar
Indiancreek
Dub asked the pertinent questions. Mileage and oil and verify pressure. Usually the pressure is an indicator of bearing ware if all other particulars are the same.
Original engine mileage and service intervals would be good to know. Verify the pressure with a mechanical gauge if you can.
Old Aug 2, 2014 | 11:16 PM
7T1vette's Avatar
7T1vette
If it drops all the way to zero, you likely have an intermittant short in the signal line to the meter. That would force the meter to read zero.
If it just drops part of the way, then comes back to normal pressure, you probably have a bad oil filter. The filter has an overpressure bypass valve in it. If that valve is bad, it could be bleeding off pressure when it should not. Since you just changed oil, that would be my choice of problem 'cause'.
Just install another filter (preferably WIX....not Fram ) and see if the problem goes away.
Old Aug 3, 2014 | 12:43 PM
loup68's Avatar
loup68
Army
If you have gasoline in your oil, more than likely your mechanical fuel pump could have a ruptured diaphragm. Lou.
Old Aug 3, 2014 | 06:48 PM
DUB's Avatar
DUB
I have not seen a mechanical fuel pump leak and actually pump fuel into the engine block where it is mounted. When it ruptures...it will weep fuel out of the housing onto the ground.
HOW MANY MILES ON THIS ENGINE????
What viscosity/grade of oil did you put into your engine???
Does the new oil smell like fuel...and the oil level getting higher on the dip stick????
Depending on how much fuel you had in your oil...you may need to change it a few times to get all of the fuel/oil mix out of the engine.
And when all is said and done....a heavier viscosity oil may be required.
Fuel in the oil can occur by a carburetor that is dripping fuel...running into the intake and int the cylinders....weeping past the rings and getting into the oil.
Head gaskets can not cause fuel to get into the oil.
DUB
Old Aug 4, 2014 | 02:10 PM
loup68's Avatar
loup68
Army
Dub, it happened to me once. The fuel pump was over twenty years old. Some dripped out, but some gas also went inside and diluted my oil. Lou.
Old Aug 4, 2014 | 03:05 PM
bashcraft's Avatar
bashcraft
The overpressure bypass valve (relief valve) is in the pump, not in the filter. There is another bypass in the piece that the filter screws onto, but that only bypasses the filter and the oil still goes through the engine.
Old Aug 4, 2014 | 05:13 PM
jkippin's Avatar
jkippin
My car has 78,000 on it I did the oil change and used synthetic(not that it matters) 10w30 oil pressure was 40 lbs hot or cold before I did the oil change. I was not sure how long the oil had been in the motor from the previous owner so that's why I changed it and it still was clean looking.
Anyway after I changed the oil it started getting lower and lower pressure no knocking sound it did hit 0 on the gauge once at idle and scared the crap out of me. I changed the sender but ir made no real difference.
Sorry for the long story but I will get to the point now. I put 15w50 in and the pressure stays right at 40 Yeah I know I am only buying time and a rebuild is in the future but a heavier oil may be what you need.
if your oil was fuel diluted you may have started to wipe a bearing check the filter
Old Aug 4, 2014 | 05:53 PM
augiedoggy's Avatar
augiedoggy
He may have washed the cylinder walls too.... either the carb is messed up or the fuel pump pressure is too high for the carb float bowls I haad that make a mess of a boat I bought that way.
you should have at least 10psi for every 1,000rpm when the engine is fully warmed up.
I had a pressure sender fail on me right after replacing a head gasket and valve seals on a jeep 4.0...scared the crap out of me.
To Low Oil Pressure
