WEIGHT Question...
Old Aug 25, 2014 | 07:25 PM
hereigo's Avatar
hereigo
St. Jude Donor '14
Default WEIGHT Question...
1979 body, no doors or front clip. No interior or windshield.
What would be a good guess on the weight?
Jerry
Old Aug 25, 2014 | 07:43 PM
Alan 71's Avatar
Alan 71
Hi Jerry,
How about 500-600 lbs.?
Regards,
Alan
Old Aug 25, 2014 | 07:48 PM
bwinterstine's Avatar
bwinterstine
I have the same thing sitting on a dolly ... I agree with Alan. I would add that when you lift it it, it will be tail heavy. You'll need to place the lift straps more toward the rear of the car to keep it balanced front to back.
Old Aug 25, 2014 | 09:00 PM
hereigo's Avatar
hereigo
St. Jude Donor '14
I have a three car garage but in a historical neighborhood. Each garage is separated with walls and has a ceiling height of 6'10".
My plan is to store body in middle garage as high as possible, support it with 2x4's bolted to 6" stud walls. It would then have room for rolling frame w/o fuel tank to be stored under it....I am not comfortable leaving body hanging by straps.
Think it will work?
Jerry
Old Aug 25, 2014 | 09:37 PM
hereigo's Avatar
hereigo
St. Jude Donor '14
Thank you Alan for the response. Light weight tackle should handle the load. 6" ratchet on light weight straps should do it. Four corners to lift. Then support with lumber....Thinking out loud fellas....
Old Aug 25, 2014 | 09:48 PM
hereigo's Avatar
hereigo
St. Jude Donor '14
bwinterstine, I have followed your build since September of last year. Guys like you, Rvzio,doorgunner, and of course Stinger12....keep me going. Mr. Alan71 makes me proud to be in his species....or am I.....
Regardless, thank you for the input, I bought an engine and trans today and hope I get to your level soon...long way to go....
Old Aug 26, 2014 | 07:13 AM
Alan 71's Avatar
Alan 71
Hi h,
You can do it too!
It's really a matter of deciding what you want it to be when you're finished and then being willing to spend the time needed to get it there.
Good Luck!
Regards,
Alan
There's a small restoration shop in western Virginia that has the same garage set up as you describe…. 3 bays right next to each other, but separated with walls. He turns out the most beautiful work I've ever seen.
Old Aug 26, 2014 | 07:05 PM
hereigo's Avatar
hereigo
St. Jude Donor '14
Assuring words Alan....I can do details and tenacious work with my hands, my other hobby is building and inlaying acoustic guitars. We will see how that translates to fiberglass, steel, and paint!
Thank you Alan...
Old Aug 26, 2014 | 09:37 PM
72LS1Vette's Avatar
72LS1Vette
I used 2X6" and 2X8" for the supports but you only need to raise the body enough to be able to slide the rolling chassis in and out.
We lifted the body in the garage, rolled the chassis out, built the body support while the body was hanging in the garage, and then lowered the body onto the support.
Rick B.
Old Aug 27, 2014 | 01:12 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Rick B.
That is so similar to how I'm about to go about lifting and storing my shark's body it's almost eerie. Primary difference is that I'm going to go ahead and raise it up as far as possible (attic mounted hoist) so I can do at least some chassis work when the weather isn't cooperating.
Old Aug 27, 2014 | 01:46 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Good idea on lifting it as high as you can to get more work done on bad-weather-days.......with the body high enough, you won't need to wear a hockey helmet to work on the frame!
Old Aug 27, 2014 | 07:00 AM
hereigo's Avatar
hereigo
St. Jude Donor '14
That looks like what I need!
Old Aug 27, 2014 | 04:42 PM
doorgunner's Avatar
doorgunner
Happy lifting........with pics, of course!
Old Aug 27, 2014 | 05:55 PM
TheSkunkWorks
Well, I might end up in a hardhat while I get used to it, as my garage ceiling is only ~9 feet. FWIW I've decided to go ahead and hang a 4' florescent light fixture under there. Just waiting for the heat to subside a bit so I can rig the chain hoist.
Old Aug 31, 2014 | 08:23 AM
bwinterstine
Your on the right track and in good hands if you use this forum for information and advice when needed. I tore apart my first vette using the expertise found here. Question is: Can I get it back together?!!!
To WEIGHT Question...
