power steering troubleshooting
Old Aug 26, 2014 | 04:48 AM
AWilson's Avatar
AWilson
Default power steering troubleshooting
I have read the papers on power steering pump installation etc. But I cannot find anything on troubleshooting. I have rebuilt my entire power steering system but it does not work at all. I would like to systematically figure out which component(s) is not working. Is there a diagnostic or troubleshooting guide someone can direct me to? Again mine currently does not work at all so please don't tell me there is air in the system. I have gone through that procedure.
Old Aug 26, 2014 | 05:17 AM
76CSRvette's Avatar
76CSRvette
What are the symptons is your pump flowing. Is there fluid disappearing. Does your car make noise when turning.
Last edited by 76CSRvette; Aug 26, 2014 at 07:43 PM. Reason: auto correct misspelling
76CSRvette's Avatar
76CSRvette
http://www.superchevy.com/how-to/vem...ring-problems/
Old Aug 26, 2014 | 06:56 PM
72LS1Vette's Avatar
72LS1Vette
Check to make sure the hose connections from the PS valve to the steering ram are correct. It's easy to cross them.
Rick B.
Old Aug 27, 2014 | 04:29 AM
AWilson's Avatar
AWilson
Rick B.
i will check but i am sure they are right as I was very careful.
Old Aug 27, 2014 | 04:32 AM
AWilson's Avatar
AWilson
Symptoms! It does absolutely nothing. There is no noise.
I don't know if the pump is flowing. How can I tell? The reservoir stays full.
Old May 22, 2023 | 08:40 AM
LifeofJob's Avatar
LifeofJob
3rd Gear
Nice to know I’m not a lone! You think you’re doing the right thing by proactively installing new parts as part of a rebuild and it turns into a nightmare!! I’m about ready to convert to manual steering!!
Old May 22, 2023 | 11:29 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Might be good to start at the beginning. Was it working before you replaced all the parts and did you perform the axle stand stop to stop and balancing procedure outlined in the paper above?
Old May 22, 2023 | 12:03 PM
vettebuyer6369's Avatar
vettebuyer6369
No real need to resurrect 9 year old post here.
To power steering troubleshooting
