Dumb question
Old Sep 6, 2014 | 09:29 AM
BLUDICE's Avatar
BLUDICE
Default Dumb question
I know this is a dumb question, but I have to ask it in case I'm missing something. My '78 non ac car - how in the world do I get some decent fresh air while driving in the rain with the windows up?
Old Sep 6, 2014 | 10:05 AM
F22's Avatar
F22
Not a dumb question at all! I wonder about that too, because I could not see anything, anywhere, where there is a fresh air source in these cars. My interior was a shell, mind you and I still saw nothing. Or are we missing something?
Old Sep 6, 2014 | 10:14 AM
augiedoggy's Avatar
augiedoggy
You drive your vette in the rain? :-)
Jk.... I take it the vent system doesn't work? Mine have "astro ventilation" which I assume GM abandoned by then...
Old Sep 6, 2014 | 12:54 PM
BLUDICE's Avatar
BLUDICE
No Astro Vent on mine. Remember the good old days you had fresh air come in at your feet by pulling a **** on the bottom of the dash? There was a duct on both sides in the engine compartment that went to the front that supplied the cool fresh air - what happen to thoses?
Old Sep 6, 2014 | 01:03 PM
Kris Tunetso's Avatar
Kris Tunetso
While I've never owned a car without AC (though my 76's AC is inop. right now) I would think that you just set the HVAC controls to "Vent" and it'd pull air through the box.
Maybe I'm wrong; hopefully someone more knowledgeable will chime in. Good luck.
Old Sep 6, 2014 | 02:24 PM
BLUDICE's Avatar
BLUDICE
That's the problem - that air is usually not that cool.
Old Sep 6, 2014 | 04:16 PM
Kris Tunetso
It's probably not intended to be cool, just fresh. If you wanted cool air you ordered AC, at least if I were the marketing guy back in the day that's what I'd have told people.
Sorry I can't help.
Old Sep 6, 2014 | 05:09 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Make sure your hood seal is good and there are no other holes from the engine compartment into the windshield wiper bay. That's where you get your outside air.
Old Sep 7, 2014 | 09:55 AM
terry82's Avatar
terry82
do you have a heater valve shut off?if the heater is shut off the air coming thru the vent should feel cool or at least not hot.
Old Sep 7, 2014 | 10:09 AM
BLUDICE's Avatar
BLUDICE
Yes, and it's working correctly.
I think I'm expecting too much from an ill designed set up.
Old Sep 7, 2014 | 10:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I think I'm expecting too much from an ill designed set up...
Sounds like you're blaming a forty year old design for local weather conditions.
Old Sep 7, 2014 | 11:41 AM
GUSTO14's Avatar
GUSTO14
Your '78 is not a non-A/C car. Well it may not have A/C now, but when it left St. Louis, it came with a ventilation system designed around A/C. It relies on the A/C in ways the pre-'76, non-A/C cars never did. I think you'll find most "modern" cars are seriously lacking in fresh air ventilation today (except perhaps in the cooler months) when the A/C is not functioning.
Restoring the original A/C may no longer be an option for you, but one thing you might consider is a system such as Vintage Air offers. It's a modern system that is very efficient, compact and with a dose of mechanical ability on your part can be installed at home. Not inexpensive, but it can make that classic into a joy to drive year around... even in South Florida.
I've seen quite a few vintage muscle cars transformed in recent years from being fair weather cars into year around cruisers by many of these modern systems. We recently installed a modern climate control system in a '69 Camaro, with a tricked out 383 and a high stall automatic. Something pretty much unheard of back in the day. Technology can be a great thing.
Good luck... GUSTO
Old Sep 7, 2014 | 07:24 PM
kjbuster1's Avatar
kjbuster1
Default ventilation
It was a long time ago but I had a '78 with A/C and wanted fresh air to the driver side. I pulled the kick panel off by the LH side and cut a hole in the fiberglass. This opened up airflow from the plenum. Used an air valve off a C-2 to control the flow. It worked.
Old Sep 12, 2014 | 01:15 PM
Priya's Avatar
Priya
Yes, those were the good old days. Unfortunately in the mid-70's the car manufacturers went to a sort of false vent setting on the heater controls that just gives you hot air inside. My 81 AMC eagle is a nice exception to that, it still has a **** that opens a door that directly lets cold air in. Now that the A/C is not working on my 79 its pretty warm inside even when its 60 outside and the vent selection is useless.
A real shortcoming in most cars produced since the mid-70's. I don't even know why they have a "vent" position, its totally useless. My 79 is cooler with the heater control in the off position than it is with it in the vent position.
Old Sep 13, 2014 | 07:34 PM
BLUDICE's Avatar
BLUDICE
That sounds like a great solution - just what I wanted to hear. But more details would be nice. Thx
To Dumb question
