Rear shock lower mount ?
Old Sep 7, 2014 | 08:13 AM
danh77's Avatar
danh77
Default Rear shock lower mount ?
The p/o of my 77 had replaced all the rear suspension pieces, trailing arms, bushings, brakes, etc and my question is this. The lower what I would call shock mounts have a stud that faces the rear of the car, it goes thru the lower portion of the spindle and the strut rod and has a castle nut on it. It looks as if there should be a cotter pin also but I dont have any there and the nuts were hand tight only. How tight are these supposed to be and should a cotter pin be installed also? As a secondary question with winter coming and the car sitting idle I think I will have the frt suspension redone, car drives very well nothing feels sloppy or leaks but figured I would then know frt and rear were all new. What all would you guys recommend replacing? Just rubber items or more? Thanks for any and all input.
Old Sep 7, 2014 | 08:24 AM
Alan 71's Avatar
Alan 71
Hi d77,
The AIM indicates the torque for that nut should be 70-80 ft/lbs.
And also that a cotter pin is used.
Regards,
Alan
