Alignment Guru's
If the rear feels loose I would start to look at strut rod bushings and stub axle play in the differential.
I also found that if they did not assemble the rear camber with the correct washers that it would not stay in alignment.
Bill
Checked operation of p.s. control valve, OK. I don't know how I missed it but I notice excessive inner tire wear. At the same time I was reading about bump steer. I thought that the excess neg camber along with the severely worn tires may change the geometry. Probably not the case. I rotated my 245 to the front and the car tracked better. I then screwed around with the tow. . .I don't advise doing this, I really goofed it up. I Purchased new rear 255's and kept 45's in front. 3 alignments later and still no resolve.
Do I start the investigation process all over again or is it the alignment... H..E..L..P
I truly appreciate the time members have given me so far. Well above and beyond the call of duty. My humble thanks.
Also, there were two different springs fitted to the steering valve, read Jim Shea's paper on this, I have often wondered whether the heavier spring was better, if a front wheel is deflected by a road irregularity perhaps it activates the valve sufficiently to make the steering wander worse? The springs are getting old and probably sacked out somewhat. Just a theory!
I shopped around, redeemed some visa points and bought the kit. http://www.speeddirect.com/wp-conten...oids-C2-C3.jpg
Used thier alignment numbers. http://www.speeddirect.com/index.php...nded-alignment
But have since adjusted the "feel" a bit to what you see in the pics above.
My car is far from original. IMO the old system just didnt feel safe. My car is a cruiser, no autocrossing or drag racing for me. Safety is my number one priority. Steering, brakes and tires, my dad told me to never cheap out on parts.
And yes it does bolt in as easy as it says in the instructions. Just loctite'd everything upon final assembly, as of a few weeks ago when I had it on a hoist everything is still as installed.
Pete,, when your car is running shake the steering wheel back and forth just to the point where the tire starts to move. Have somebody move the wheel back at forth and you look under hood and under car and see where (if) you have any excess movement somewhere. If your steering parts are all new and tight with no slop then its an alignment issue.
Dodosmike
Dodosmike
P,S. How do I find Jim Shea"s paper. I looked and 3 pages of threads came up. MaMaMia!
Last edited by PeteL46; Sep 20, 2014 at 08:04 PM. Reason: EDIT: How do I find Jim Shea Paper.
Thanks for your help, I'll let the thread know what I've found.
EDIT: not sure how to check preload but I'm sure I can find it.
