Name of this Switch?
Old Sep 14, 2014 | 03:40 PM
Too Slow '90's Avatar
Too Slow '90
Default Name of this Switch?
The light colored switch on top of the A.C. duct. It has two screws however my new harness has a plug. I am trying to find out if it's the correct one.
Old Sep 14, 2014 | 04:57 PM
hugie82's Avatar
hugie82
The interior light delay is an orange box but I'm wonder if someone wired a different one in there?
Old Sep 14, 2014 | 05:21 PM
Too Slow '90
It's a switch to operate the door on the duct...I think. I don't think it's correct for '68 but I can't tell for sure until I find out the name.
Old Sep 14, 2014 | 05:30 PM
DUB's Avatar
DUB
That is the vacuum switch that allows you to close off the vacuum to your hot water shut off valve when you have your A/C on. when you move your 'HOT-COLD' arm on your heater control in the console/shifter plate area...you will see the cable move and contact a plunger in this vacuum switch.
You did not state the year...nor did you state if what appears to be electric connectors in that area...if they are truly that or not.
Also that spring in the upper right corner of this photo should not be there.
I do not understand what you wrote about how your 'new harness has a plug'??? What type of harness...electrical or vacuum????
The more descriptive of information given (with or without a photo) better 'paints' a good picture so proper information and advice can be given.
DUB
Old Sep 14, 2014 | 05:34 PM
DUB's Avatar
DUB
IF it is a 68....I have not seen this vacuum switch on top of the heater box...that vacuum switch came later...but it actually still can be used to shut off the hot water. I just recently did just that on a 1974 so when the A/C was set to any setting (Max, normal, bi-level)....as long as the roller wheel was rolled all the way to the top...there would be NO hot water getting into the heater core.
DUB
Old Sep 14, 2014 | 05:48 PM
Too Slow '90
DUB
I must be getting senile. It is a '68. It's been abused through the years and there are many things that are not correct. The connector I refer to is an electrical connector. Currently it has two wires (Bubba'd) screwed to terminals on the switch. This switch is illustrated on my '68 AIM and shows a plug connector. (Two Blade)
Old Sep 16, 2014 | 03:49 PM
Too Slow '90
Anyone?
Old Sep 17, 2014 | 06:58 PM
DUB's Avatar
DUB
I will look into it.
DUB
Old Sep 18, 2014 | 12:19 PM
7T1vette's Avatar
7T1vette
Not every 'alteration' to a vintage car is "bad". Sometimes, owners make UPDATES or improvements that the factory made in later models. Just because "it wasn't like that from the factory" doesn't mean the change/modification wasn't useful nor wasn't done well.
Whenever you find a 'difference' that you don't expect, investigate to find its purpose and test to see how well it works. You may want to leave it "as is".
Old Sep 18, 2014 | 12:30 PM
thegazman's Avatar
thegazman
Default thegazman
Corvette Central used to sell an electric vacuum switch conversion made by Corvette Clinic (now out of business). There was a switch that attached to bottom of your heat control that operated the electric vacuum switch on top of your heater. This was supposed to prevent the spring in the mechanical vacuum switch from opening the heater door from vibration while driving.
Old Sep 24, 2014 | 12:09 PM
Too Slow '90
I hear you but this car loaded with...let's say updates. Melted wiring harness, incorrect and modified dash and so on. Most of it I can figure out but the details get me.
To Name of this Switch?
