Which water pump on my crate engine?
Old Oct 3, 2014 | 12:41 PM
kaz1961's Avatar
kaz1961
Default Which water pump on my crate engine?
I have an 80 with a crate 350 in it. I need to replace the water pump, the one in the car now has a casting number of 30998 which doesn't seem like the right number. How can I be sure I get the right pump? Would any pump for a stock 350 fit? Any help greatly appreciated.
Old Oct 3, 2014 | 01:24 PM
MelWff's Avatar
MelWff
you have to determine the pump shaft diameter and length, there are long and short pumps. Read this link with the dimensions
https://summitracing.custhelp.com/ap...etail/a_id/913
Old Oct 3, 2014 | 06:36 PM
DUB's Avatar
DUB
Yes...if you ordered the pump from a supply house it will bolt on just fine....THE PROBLEM can be if you have all the correct components mounted on the engine...especially the air pump bracket and A/C mounting bracket...when you get the pump on...you might find that the casting of the water pump on the right side is a little bit longer. And if you go in and bolt one on and use all the correct brackets...the aluminum smog pump bracket WILL BREAK.
DUB
To Which water pump on my crate engine?
