Pulling the trigger on AFR's
Old Oct 17, 2014 | 09:30 AM
  #61
scott foxwell's Avatar
scott foxwell
Originally Posted by gkull
What 63mako said about cfm and low lift numbers is kind of trivial. If you look at a roller lobe very little time is spent on the lower lifts compared to the large amount of time spent at or near the highest lift. That is why roller cams are so superior to their flat lifter cousins.
The other thing about 406 ci and a roller cam is that you will have more vacuum and TQ. People forget about larger heads making more TQ across the whole rpm range compared to a smaller head.
My street vette has had single planes for about 30 years and 160,000 miles of driving. You have to be smart about matching components. You use the smaller plenum singles like the Weiand 7530 or some number like that
This is really common thinking but it couldn't be more wrong, especially the comment about larger heads making more tq across the whole rpm range. Quickest way to kill low rpm tq is with intake ports that are too big for the application. A small plenum will also kill low rpm torque compared to a larger one.
Old Oct 17, 2014 | 09:33 AM
  #62
scott foxwell
Originally Posted by 76strokervette
Just to update earlier information on the pro-filer 210 head the flow numbers are 288/194 @.500 with 2.08 intake valve.This head cannot be ordered with the 2.055 valve as listed with Stan Weiss.At least from pro-filer anyway.The afr 195 will work fine for the op but won't it fall short above 6000 rpm?The csa seems a little small above 6000 rpm.If the air speed gets too high won't the port go into choke?
What do you base your CSA comment on? What is the head's CSA and what does the engine want, and at what RPM? Are you talking about minimum CSA, average CSA, CSA @ the short turn, CSA through the valve...???
Old Oct 17, 2014 | 09:39 AM
  #63
scott foxwell
Originally Posted by DucatiDon
Who has done math on volume of air for different displacements and runner sizes?
How much air can a 383 push vs a 427 through 195, 220, 230 runners, and the resulting velocity? Might be interesting....obviously volume will be dependent upon rpm...
What's maximum efficiency?
That's a lot of variables....lol
Max volume of air is secondary to the velocity. An engine is an air pump...it displaces a positive amount of air based on bore, stroke and rpm. This does not change. The cylinder heads and cam regulate that airflow to determine how much power the engine is going to make, and at what rpm. IDEALLY, it is not up to opinion, it's a matter of physics. The debate comes in when we start describing the power and it's characteristics. How much, and at what rpm....what kind of power do you want. That is an entirely subjective discussion with unlimited variables.
Old Oct 17, 2014 | 09:40 AM
  #64
76strokervette's Avatar
76strokervette
Minimum csa.
Old Oct 17, 2014 | 09:49 AM
  #65
scott foxwell
Really......... If you have a lobe listed at 250 degrees @.050 and the .200 lift duration is 166 I would tend to say that the valve is spending most of it's time in excess of the .400 lift.
My other part of the statement was about Some listed dyno runs where the larger head more power on the same motor across the rpm range. So this supposed lower lift flow numbers don't pan out in the real world
Using your own logic, lets look at it as a matter of time. Since you're spending so little time at the low lift numbers, doesn't it make sense that you'd want them as good and as efficient as possible? Isn't the goal to fill the cylinder?
Do you know where the greatest pressure differential occurs during the intake stroke and intake valve event?
If you're ignoring low lift flow and velocity you're leaving power on the table. Again, it's a matter of physics, not an opinion.
Old Oct 17, 2014 | 09:50 AM
  #66
scott foxwell
Minimum csa.
OK, what is the min. CSA of that port and what does the engine require?
Old Oct 17, 2014 | 10:00 AM
  #67
76strokervette
I'm asking about the op's 406 cid and the 195 afr head.I personally do not know the csa of that port.But at 195cc shouldn't it be around 2.1 to 2.2.
I agree for what he wants he will be fine I 'm just curious what will happen if he would want more rpm(6500 +).
Old Oct 17, 2014 | 10:09 AM
  #68
scott foxwell
A 406 making peak power at 6000rpm wants a minimum cross section of 1.98" sq in. to maintain (a specific) velocity. If you want to move the peak power number up in the rpm range and maintain that same velocity then you have to increase the area. Same rules apply to the valve size. We need to maintain an "ideal" velocity through the valve opening. Velocity through the min. area and through the valve are directly related.
We can also look at the air demand of that engine. Lets say he uses an intake lobe of 240 @ .05. For 100% volumetric @ 6000rpm, the engine wants 321 cfm. That head will supply that at ~.475 lift. It has plenty of cross sectional area and plenty of airflow.
Old Oct 17, 2014 | 11:06 AM
  #69
63mako's Avatar
63mako
St. Jude Donor '08-'09
You are right. The AFR 195 is too small above 6000 rpm if the OP was running over 6000 rpm, it will hit a ceiling at some point above that. Point being this build will not be turning 6000 rpm with the cam and dual plane intake he selected. The heads won't be the first thing to limit RPM the cam and intake specs will. That said the 224/230 cam with sub .550 lift and dual plane matches the AFR 195 well with HIS build specs, intended use and combination. This engine will make power off idle to 5500. Over that RPM will be counterproductive for the combination.
Originally Posted by sstocker31
I going to keep my 224/230 @ .050 .535/.544 with Comp 1.6 Roller rockers for now....I'd like to see the difference a head change / intake only makes. I may step it up some at a later date.
Old Oct 17, 2014 | 11:19 AM
  #70
scott foxwell
Originally Posted by 63mako
You are right. The AFR 195 is too small above 6000 rpm if the OP was running over 6000 rpm, it will hit a ceiling. Point being this build will not be turning 6000 rpm with the cam and dual plane intake he selected. The heads won't be the first thing to limit RPM the cam and intake specs will. That said the 224/230 cam with sub .550 lift and dual plane matches the AFR 195 well with HIS build specs and combination. This engine will make power off idle to 5500. Over that will be counterproductive
Kind of contradict yourself here...
The heads have plenty of cross section and airflow to carry past 6000rpm if that's the goal. Where it makes peak power, and where peak rpm is are two different things. I think this combination will carry nicely past 5500.
Old Oct 17, 2014 | 11:49 AM
  #71
63mako's Avatar
63mako
Operating range, peak power and redline are all different things. 6000 RPM shift points will be fine, will be past peak power but keep him in the fat part of the operating range on upshifts. I really think it is a killer street combo.
Old Oct 17, 2014 | 11:52 AM
  #72
scott foxwell
Old Oct 17, 2014 | 12:06 PM
  #73
OMF's Avatar
OMF
OK....you guys got me all f'd-up......i'm going to order a 195 head for the left side along with a 1 3/4" header, and a 210 for the right side along with 1 7/8" header.
Then I'm going to find a mechancal fuel injection setup....choke it down to 1 1/2" on the left side, and run her wide open on the right side.
That should make everyone happy.....
I'll let you know how it works out....
Thanks for the advise
Old Oct 17, 2014 | 12:09 PM
  #74
scott foxwell
LOL...lot of "opinions" out there. Some have been there, done that.
Did you see this?
https://www.corvetteforum.com/forums...ual-plane.html
Old Oct 17, 2014 | 12:13 PM
  #75
StraubTech's Avatar
StraubTech
Scott has worked for both Dart and Alan Johnson. Two premier cylinder head mfgs. His math equates to power per application.
Edmonton, Tell my Randy at ProStock I said hello..Good people at that shop.
Old Oct 17, 2014 | 02:10 PM
  #76
gkull's Avatar
gkull
To make a general statement about street and lets use AFR heads. Heads with high peak numbers tend to also have great low lift numbers. I'm not sure why AFR 210 lags so far behind at only the .400 lift number and then exceeds the 195 by such a big margin at .500.
But when you feed input data to an engine simulation program the more info you can input the more accurate it becomes. So if you add up the .100, .200, ..... .500 cfm intake flow rates of the 210 VS the 195 The 195 appears to win by a margin of 5 cfm just using those numbers.
Now look at the roller cam lobe and see how much time is spent at or near max lift like the posters .530 lift. You are spending much more time getting getting 292 cfm vs the 195 heads 275 cfm. That time spent at .500+ lift more than off sets the 5 cfm mathematical lead of the smaller 195
406 is not a small motor and like me and every other hot rodder out there is never happy with the power after awhile and they seek bigger and better. Well if you buy the big heads to begin with you don't have to buy another set for your next project. I bought 227 cc for my 383 because I didn't want to go over board and later on I had to put in a bigger cam because it needed it.
Flow @ .200
AFR 195- Intake 146 Exhaust 119
AFR 210- Intake 145 Exhaust 110
Flow @ .300
AFR 195- Intake 201 Exhaust166
AFR 210- Intake 199 Exhaust 158
Flow @ .400
AFR 195- Intake 274 Exhaust 197
AFR 210- Intake 255 Exhaust 192
Flow @ .500
AFR 195- Intake 275 Exhaust 213
AFR 210- Intake 292 Exhaust 210
  #77
Little Mouse's Avatar
Little Mouse
Dart makes cylinder heads and are premier. I thought only AFR made cylinder heads they have the best advertised airflow numbers.
They have a 220 series that's never advertised on there web site you have to look for it to even find it on there web. fully CNCed problem is its not a smaller head it starts out at 220 and goes up in size from there.
Brodix has some very good heads that are not as cast but again they don't offer the smaller heads that way and there pricing is higher.
To Pulling the trigger on AFR's
Old Oct 17, 2014 | 02:24 PM
  #78
63mako's Avatar
63mako
Flow @ .200
Flow @ .300
Flow @ .400
Flow @ .500
If you called AFR and gave them the specs and intended use on this build they would recommend the 195. Higher port velocity causes a ram effect not seen in these numbers also, likely the reason for the elevated lower lift flow numbers with a smaller port. Effects performance more than you would think at low end, midrange. You are a guy that runs high rpm and races. If you look at the item descriptions from AFR for the 195 and 210 you will see for your 3000-7000 rpm and racing the 210 is a better option for your intended use, RPM range and CI.
Old Oct 17, 2014 | 02:39 PM
  #79
StraubTech's Avatar
StraubTech
there are a lot of premier parts out there....just need to know how to make premier combination. I have 640CID engine here that was $59K. It makes 1200HP. The customers brother has a 532CID engine with good parts but not as nice as the 640....at $31K it makes 1200HP.
Old Oct 17, 2014 | 02:40 PM
  #80
StraubTech's Avatar
StraubTech
Mr. Wehunt's engine proves how good the 220's are.
