Body mount question ...
Old Oct 22, 2014 | 08:27 PM
The Phantom's Avatar
The Phantom
Default Body mount question ...
So I'm pulling the body this weekend to overhaul the frame an related components this winter, it is a 71 coupe I believe the body mounts are solid. Is there a better body mount option to install, an upgrade for the stock ones?
Thanks,
Dave
Old Oct 22, 2014 | 09:50 PM
gcusmano74's Avatar
gcusmano74
The 73 and newer mounts are a rubber and metal sandwich, of sorts. They are a bit thicker (maybe 1/4" or 3/8"?) than the solid metal mounts, and will raise the body off the frame that much. They also will improve the noise, vibration and harshness isolation. The factory had a separate bushing set for the coupe and convertible (the convertible #2 and #3 bushings were softer, and marked with white paint), but the aftermarket supplies only the coupe set.
Ya pays yer money and you makes yer cherce.
Old Oct 23, 2014 | 04:12 PM
SB64's Avatar
SB64
Thanks,
Dave
I would suggest that you go with the ones that GM intended for the car. Pulling the body off the car requires enough time and then putting it back and forth until you shim the car properly is also hard. You also want to tape together what you take off and label what mount and side they came from. It's not like adjusting the hood or door. More involved. Good Luck
Roger
Old Oct 24, 2014 | 06:01 PM
The Phantom
You know I've got enough on my plate with the issues this car already has ... why make it more difficult! The KISS rule wins, thanks for the replies gents.
Dave
Old Oct 24, 2014 | 06:29 PM
DUB's Avatar
DUB
If you go back with the aluminum thick spacers (bushings)...I would apply a layer of thick cellophane tape to each side of them before putting them in and trim the excess off. You won't be able to see that it is there and it keeps the aluminum and metal from touching directly...which can cause for galvanic action to occur if they do...and you add salt into the equation. It goes crazy and the aluminum begins to corrode.
DUB
Old Oct 24, 2014 | 08:26 PM
The Phantom
DUB
Good idea thanks.
Dave
To Body mount question ...
