Power window regulator removal
Old Nov 3, 2014 | 11:08 AM
rickmt57's Avatar
rickmt57
Cruising
Default Power window regulator removal
I have a 68 corvette convertible and the passenger window is stuck, it wont go up it wont go down I hooked up a battery charger and got it to move just a hair before it froze. Every article Ive read says put the window up to remove the regulator. My problem is I cant move the window its about 1/3 of the way up and its stuck there. Any ideas on how to proceed to remove the regulator and motor so I can either rebuild or replace. I cant line up the holes either just to remove the motor because again its stuck where its at. Any help would be appreciated ... thanks
Old Nov 3, 2014 | 12:45 PM
BKbroiler's Avatar
BKbroiler
Try hitting the motor with a hammer while you hold the switch up or down. Sometimes that will free it up temporarily.
Old Nov 3, 2014 | 06:21 PM
DUB's Avatar
DUB
If you can not get the motor to move the glass. You are in for one heck of a journey.
On the 69-82 corvettes that have a motor that is dead....I have had to go in and CAREFULLY remove the motor so I them could be able to manually move the window so I could get it out...then the regulator.
This is NOT going to be easy...by any stretch of the imagination. I have been there.
DUB
Old Nov 3, 2014 | 06:38 PM
hugie82's Avatar
hugie82
Make sure it didn't fall out of the track and jam a roller but above advise is spot on. Don't forget the regulator takes a giant 1/4 rivet that holds it in. Take your time and take a lot of picks. If one part isn't in right, it won't work.
To Power window regulator removal
