69 BBC Starter Wiring Help!
Old Nov 3, 2014 | 01:58 PM
Factor's Avatar
Factor
Default 69 BBC Starter Wiring Help!
Hi all,
OK! so my 69 was converted to HEI by previous owner. I am staying HEI with the new 454 putting in.
I got a Powermaster High Torque starter...it only has the ignition lead, I believe that is the "D" side. No "R" side is needed.
they have said the "R" side in only for a resister and is not necessary if a car was converted to HEI...
So, questions....what is the R and D of the starter wire hookups for?
Thanks!
Ron
Old Nov 3, 2014 | 02:23 PM
MelWff's Avatar
MelWff
Never heard of a D connection, R for the coil wire and S for the switch wire on the solenoid, no instructions came with the starter?
http://www.powermastermotorsports.com/faq-starter.html
http://www.powermastermotorsports.co..._GMMiniSta.pdf
Old Nov 3, 2014 | 03:50 PM
Factor's Avatar
Factor
HI Mel!
Yes...sorry...the R side. I have an HEI, but they still connected the R& S....
according to powermaster sheets and links you supplied...it says no R is necessary, unless there is no cranking...
gonna check into that kit...
which color is "S" wire from the harness?
thanks,
R
Old Nov 3, 2014 | 05:19 PM
Factor's Avatar
Factor
yes...btw those are what came with it. I am trying to understand what came stock on the car, then what I have, thus what I will need...
Old Nov 3, 2014 | 05:28 PM
CanadaGrant's Avatar
CanadaGrant
The small wire on the inside close to the block is needed. The outside wire (looking up from under the car) is a coil booster for starting and isn't needed. Sounds stupid but it's true....
Old Nov 4, 2014 | 02:49 PM
Factor's Avatar
Factor
Hi CanadaGrant! so the R wire is not needed?
what COLOR is the one NOT needed??
thanks!
To 69 BBC Starter Wiring Help!
