Hydroboost Brake Upgade: Looking for Comments
are there any better designed/performing vacuum boosters out there now? or should i just stick with an OE replacement?
What year are you putting git in????...It makes difference.
And more importantly... what side is you oil dipstick located????
DUB
its going in my 69 small block, and my dipstick is between plugs 5 - 7. i think....
The booster for your car is stamped completely different...and it is stamped out in a way that if the oil dipstick is correctly installed and positioned...you can get to the handle of the dipstick and pull it out easily and re-install it without obstruction. IF you put a booster from the later years...it conflicts with the dipstick...which will have to be bent and moved to clear the booster outer housing.
The later years have a recessed 'pocket' in the stamping of the outer housing...and when the master cylinder fits to it...you can NOT see the contact point of the master cylinder where it touches the booster because it is tucked back inside this stamping. The early design is the other way...the outer housing is stamped and the mounting area for the master cylinder pokes outwards (so-to-speak) and you can clearly see the contact point where the master cylinder touches the booster.
DUB
This is just me, but I have a hard time driving his car. It is jerky and odd with no pedal feel. I hate the clutch.
My present motor is about 9 inches of vacuum @ 1200 rpm idle. yes it is a little over cammed solid roller. My braking and steering is fine. It is good enough to run it around a 4.2 mile road racing track and drive on my local mountain roads around Lake Tahoe
I have driven 2 C3s and a '69 Camaro with hydroboost, and they all felt overboosted and touchy. Didn't really like the weird pedal feel, to be honest.
That said, I think if ya got lots of power and race/often push the limits of the car, then that is a different story completely as I know some of you do.
For now, I decided to modify the 1" AFR spacer by adding a 3/8" NPT to 8 AN fitting and to it, attach a 45 degree 8AN swivel and stainless braided hose to the vacuum booster. Looks like it will clear everything and didn't cost much to do.
Really short on funds, engine build is way more then I figured and I just closed on a deal Friday to purchase a 1992 ZR1 that has been in the works sense last spring. My wife is a saint.
The brakes are the same thing. If I drove it enough I would get used to lack of resistance. Just a learning curve.
