Hydroboost Brake Upgade: Looking for Comments
Old Nov 4, 2014 | 11:29 AM
KJL's Avatar
KJL
Default Hydroboost Brake Upgade: Looking for Comments
Have engine out of car and am considering swapping over to he hydroboost system. The brakes have been upgraded to Wilwood but other than that the system is stock. What are the advantages and disadvantages over the traditional vacuum assist can? I run a stock power steering setup which of course leaks, I have a new valve to install but eventually may consider going to a steeroids type system.
Will this wear out me rebuilt master cylinder quicker? If i run out/low of power steering fluid or the belt breaks to me pump, will the breaks still work?
Thanks.
Old Nov 4, 2014 | 11:39 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I don't care for the system. Had it on a previous vehicle (was installed by GM when car was new), and it didn't provide much feed back because of the hydraulics and if the belt broke (which occured once to me) the brake pedal went extremely stiff and I lost most of the breaking capability. It doesn't increase your braking capacity, just adds more boost so you have a lighter pedal.
If your stock system is working fine and you don't have a low vacuum condition, I wouldn't switch. JMHO
Old Nov 4, 2014 | 11:43 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
One of the best upgrades I have made, comes with an emergency charge cylinder if I am not mistaken to enable you to stop if the belt breaks and you also can stand on the unpowered brakes to get to a stop.
The power steering pump is cheap if you buy a re-manufactured one and nothing has worn out in the 7 years since I have had them. The hydroboost system is great as you will find out the first time you use them
Old Nov 4, 2014 | 12:23 PM
pauldana's Avatar
pauldana
this
Old Nov 4, 2014 | 12:33 PM
jb78L-82's Avatar
jb78L-82
As noted above, hydroboost will do nothing to increase the braking performance of the brake system-it will provide more power brake assist which makes the pedal feel much lighter-power assist on steroids.. If you prefer a more assisted brake pedal, than the system is for you…
I have driven cars with hydroboost and like Jason above, I do not care for the system. I prefer a firm hard brake pedal with linear assist since it provides better pedal feedback…just me.
Old Nov 4, 2014 | 12:41 PM
Hofs01's Avatar
Hofs01
With my cam, I have no vacuum to speak of so it was either Hydroboost or manual, I went with the hydroboost and I truly love it. one of the best upgrades I have made to date.
Old Nov 4, 2014 | 12:52 PM
jb78L-82's Avatar
jb78L-82
That would seem to me the perfect application of hydroboost. I can see it on my car with the stock brake s system (which is pretty awesome even today) with braided SS hoses and upgraded performance pads...
Old Nov 4, 2014 | 01:20 PM
pauldana's Avatar
pauldana
ok... a little more detail from me....
manual.... very linear peddle but much more foot pressure needed
Vacuum.... more mushy, easy foot pressure, but with a mushy feel... and you need car vacuum
HydroBoost.... very linear like with manual, very easy foot pressure like vacuum, and zero mush.
Hrdroboost is the best in all categories.
one of the top 5 mods for a C3
we have 5 vettes... C4, C5, C5 Guldstarnd, C6 ZO6...
And the C3 Hydroboost has the #1 best feel of them all... Danny is actually going to go HydroBoost on his C5 427 Guldstarnd... its that much better.
And we are now starting a 67 Mustang 427 750hp track car... 2500lbs... it will have a HydroBoost.
Old Nov 4, 2014 | 01:52 PM
Danish Shark's Avatar
Danish Shark
I've been wondering about the emergency canister. Is it a closed system that somehow gets re-charged when the pump starts running again or is it a one time deal?
Old Nov 4, 2014 | 02:17 PM
pauldana's Avatar
pauldana
canister will hold about 3 full brake pushes after pump goes out... more than the vacuum unit does if motor stalls. and as soon as the pump turns again instant brakes.
Old Nov 4, 2014 | 02:40 PM
jb78L-82's Avatar
jb78L-82
Must be a personal thing but I cannot see hydro boost on my 2010 C6Z06. The brakes and feel are awesome stock. If any feel needed changing, nothing a pad change would not address especially with a 6 piston front fixed caliper. As stated above, the C3 system on my 78 is terrific and my pedal is firm, linear, and has just enough boost for me. I don't want a super light pedal. Maybe the C5 with floating calipers would benefit more since that design inherently has poor feel and non linear brake action from the non racing caliper design...
The difference between the C6Z06 and C5 brakes is night and day...
Old Nov 4, 2014 | 06:39 PM
74modified's Avatar
74modified
I like my hydro boost. I am using a Astro Van unit with Jeep steering. It may not be for everyone, some find it too sensitive. Because the hydro can generate more line pressure than a vacuum boost, I would use braided flex lines.
Old Nov 4, 2014 | 06:45 PM
KJL's Avatar
KJL
I have hard and braided lines every but that short span in the rear between the hard line frame and braided line trailing arm interface. I replaced my stock canister some years back with an aftermarket unit. I never really liked the feel. Seemed to almost not be working, it is a small improvement above no vacuum at all.
Old Nov 4, 2014 | 06:56 PM
74modified's Avatar
74modified
Well the boosters are a "multiplier" of your leg effort. So - if everything is the same - pedal ratio, master bore size, and leg pushing pressure, the hydro will put out almost double the line pressure of a vacuum. So in a panic stop, you could slam a lot of pressure into old rubber lines.
Old Nov 4, 2014 | 07:11 PM
DUB's Avatar
DUB
I have installed a couple of HyrdaTech hydroboost systems in a couple of resto-mod C2 Corvettes. And I can say from being the one who felt the brakes before and after...the Hydra Tech systems made all the difference in braking. MAJOR IMPROVEMENT.
http://www.hydratechbraking.com/
DUB
Old Nov 5, 2014 | 12:38 PM
jb78L-82's Avatar
jb78L-82
I just drove yesterday a 2014 2.0l ecoboost 240 HP rental car Ford fusion and compared to ALL my cars including the 10 Z06 and 78 L-82 when I first stepped on the brake in the Fusion, holy crap-too much brake boost--head through the windshield feel. Car felt like it had Le Mans brakes but in reality-NO! I don't like cars with over boosted brakes-no feel and too much assist. You don't want brakes that will upset the balance of the chassis on first application. MUCH prefer a harder, firmer, linear brake pedal..especially if you drive hard or race…
I think that if I had a spare $500 to spend on my C3, I can think of many other things that I would spend the $500 on besides hydroboost when you have terrific stock brakes that come on a C3...
Old Nov 5, 2014 | 12:52 PM
KJL's Avatar
KJL
Is the amount of boost adjustable? I don't care for too much boost either. I have a heavy foot as it is.
To Hydroboost Brake Upgade: Looking for Comments
Old Nov 5, 2014 | 06:34 PM
DUB's Avatar
DUB
The choice of brake pad can aid in softening the 'grip' when the pedal is applied. The 63 SWC that has this Hydra tech system is fine...very manageable ( resto-mod with all newer era brakes etc)....the 67 that I installed this Hydratech system in needs the pads to be changed due to it will stop and leave your teeth on the front bumper. BUT...that is expected due to the 67 had only a Willwood master cylinder and were manual brakes (no vacuum booster)
DUB
Old Nov 5, 2014 | 07:08 PM
74modified's Avatar
74modified
DUB
The pad you choose can make a difference. You wouldn't want to turn the hydraulic pressure down because you wouldn't have enough pressure in the reservoir for stops if/when the engine stopped or lost hydraulic pressure. The master cylinder could be changed to allow a longer stroke but would also make the pedal easier to push.....inverse is also true.
Old Nov 5, 2014 | 07:42 PM
KJL's Avatar
KJL
It sounds like it certainly does what it us supposed to do. The issue is personal taste. I guess I should wait and see how the new Wilwood calipers feel before I decide. Just thought it would be easier to do while the engine was out of the car. My PS pump is a real bitch to get to.
