Read our "lips": IF THE METER MOVES WHEN YOU APPLY A SMALL VOLTAGE TO IT, THE METER IS FINE!!!
Put key in ignition and turn to ACCESSORY position; watch ammeter as you turn on your headlights (they won't come up, of course; but they will light); the current to power the lights should cause the ammeter to go to the 'discharge' side around 5 amps. If you depress the "Brights" floor-pad button, that will move to around 10 amps.
If that test shows nothing on the ammeter, then there is a problem somewhere in the wiring circuit going to the meter or with the connections to the meter in the dash area.
The meter obviously works. Locate the two orange fusible links in the ammeter circuit(one attaches to the horn relay and the other is under the wiper motor where two #12 wires are spliced together). Then check for continuity from the meter connection to the end of the appropriate fusible link.
DUB: I don't mean to override the OP but noticed your in Charlotte. Are you in a Corvette club of any sort? If so, website?
Ammeter needle doesn't move on my 1972 BB, a/c, pw, pb, ps 'Vette. Charging system seems to work OK. When I got the car about 1 1/2 years ago it moved a little for a short time. Now I am checking it out. With battery connected and two leads off ammeter I read 12.4v on both. With engine running I read 14v on each. When I check resistance with wires off ammeter but ammeter in console I read 0 to .4 ohms resistance. When I connect 1 1/2v battery across the terminals, ( ammeter still in console but disconnected), the needle immediately goes full scale. Any thoughts on what is going on and how I can determine what to fix?
Finally my ammeter is working. It appears the fusible link at the horn relay was creating too much resistance. I ran a new line with a 2 amp fuse from there to the ammeter and it works.
Thanks to everyone for your assistance. I never would have found the problem without your help.
Phil
That's cool Now go to your local parts store that has a HELP section and buy the correct fuseable link. Fix it right, i.e., correctly.
Pete
