cam advice.....
Old Dec 1, 2014 | 06:18 PM
Fredscott's Avatar
Fredscott
Default cam advice
Originally Posted by StraubTech
Heads get set up for max lift, not rocker ratio. Somebody is not explaining something correctly to you. Keeping with this a spring that is set up for .700" max lift and you put a .500" lift cam is not good. Since Spintron testing has come around to the industry we have proven that max cam lift needs to max the spring out to around .050" before coil bind. Some feel .070". Some feel right a zero. Large amounts of clearance after max lift promotes spring surge which has been proven in Spintron testing to destroy valvetrain with bad harmonics.
You need to find out what the max lift the heads have been set up for. What is the seat and open pressure of the springs.
Velocity is king on the street. This gives you instant throttle response. The super vic is not going to be a good choice on this engine.
The heads are being checked so I will get all pressures and max lift
Old Dec 1, 2014 | 06:50 PM
StraubTech's Avatar
StraubTech
Once you have this info then you can make better decisions.
Old Dec 1, 2014 | 08:53 PM
Fredscott's Avatar
Fredscott
It seems that the more information I get the more confused I am.....such is life.
I will post that info tomorrow and hopefully I can get this figured out with some more help.
Old Dec 1, 2014 | 09:18 PM
cv67's Avatar
cv67
St. Jude Donor '05
Beter to have a properly sized intake if it means a quick port match maybe even some attention in the plenum area than an intake thats way too big to begin with. 2000 stall dont get carried away wiht the big stuff on the motor.
Old Dec 2, 2014 | 04:25 PM
gkull's Avatar
gkull
1.7 ratio is not h roller friendly
Old Dec 2, 2014 | 05:09 PM
StraubTech's Avatar
StraubTech
Why not? Although the cam core size is different, BBC and LS1 are both 1.7 from the factory. The LS engine has always been a Hyd Roller.
Old Dec 2, 2014 | 07:04 PM
Fredscott's Avatar
Fredscott
The supervic port size is identical to the AFR port size...what would the reasoning be for having a smaller port on the manifold as opposed to the head?
Also, Im still waiting for the valve and spring info....when I determine valve opening(travel) and spring pressures this should greatly help me in figuring out which cam will be appropriate?
Old Dec 2, 2014 | 07:49 PM
Fredscott's Avatar
Fredscott
I would really like to keep the 1.7's....there just isn't a load of money to invest.
Old Dec 2, 2014 | 08:01 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Best option is to have ports match and operating range of intake match the operating range of the cam. The super Victor has an operating range of 4000-8000 rpm. Hot hydraulic rollers usually have peak HP around 6000 RPM and sub 6500 redline. Your giving up a lot of bottom end and midrange with that intake. This one matches your ports and has a lower operating range, closer match. Peak power don't win races. Highest average power across the operating range does. http://www.summitracing.com/parts/WND-7530/
The Super Victor will not fit under your hood.
Old Dec 2, 2014 | 08:55 PM
Fredscott's Avatar
Fredscott
I see what you mean now. I've already run the super Vic and have a hole in the hood for the air cleaner.....can I use a spacer to raise the carb to the level I need it? What do you think about the tall Vic jr?
Old Dec 3, 2014 | 01:52 AM
bluedawg's Avatar
bluedawg
Wouldn't hydraulic rollers that use 1.7's have a different ramp rate ground into the cam core, need better lifters and higher spring pressures to maintain valve train stability?
DO MA NEU!
Old Dec 3, 2014 | 08:57 AM
StraubTech's Avatar
StraubTech
DO MA NEU!
Crane was good about telling people what core size a lobe was designed for. CNC grinding has changed this but lobe profiles and manual machines are still used today.
The OP if in fact he does have 1.7s will need a hyd roller cam profile that will accept 1.7 ratio and not cause any issues with valvetrain.
Old Dec 3, 2014 | 10:31 AM
  #33
gkull's Avatar
gkull
do you like to argue? are we talkong about a BBC or a LS motor?
Old Dec 3, 2014 | 11:19 AM
  #34
76Rat's Avatar
76Rat
You guys are confusing me. From the first post it looks to be a SBC 406. 1.7 rockers? Why?
Old Dec 3, 2014 | 11:24 AM
  #35
StraubTech's Avatar
StraubTech
The same cam lobe profiles are put on various makes of engines. As long as the lobe has a velocity profile that will work with a 1.7 rocker it can be used on a SBC. The lobe has no idea what engine it is. I do fine it strange that a SBC has a 1.7 rocker ratio.
Old Dec 3, 2014 | 11:31 AM
  #36
StraubTech's Avatar
StraubTech
Example
SBC 280HR Comp
SBF 280HR Comp
BBC 280HR Comp
Same lobe, 3 different engines, 3 different rocker ratios, all Hyd. Roller
Old Dec 3, 2014 | 01:04 PM
  #37
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I talked to Red at Comp Cams years ago and he talked my out of 1.7 rockers basically said the cam I have is street roller and you are going to put more stress on the springs or have to buy a higher pressure spring which would reach the limits of what they considered a "street roller" and making longevity a problem.
He said if I want more lift get a bigger cam. I went with 1.6 rockers and everything worked fine
To cam advice.....
Old Dec 3, 2014 | 01:21 PM
  #38
MotorHead's Avatar
MotorHead
This tells me the books you have been reading and the outdated S/W you use has not informed you that don't compare a small block chey to a big block or LS engine especially when it comes to cam and valve train components. These are all different engines and comparing it to LS engine in ludicrous.
Old Dec 3, 2014 | 01:23 PM
  #39
StraubTech's Avatar
StraubTech
Your personal attacks must come from something that I have done to you. I don't know what is or when I offended you but I will apologize in public right now for what ever I have done.
Now in my "ClueLessNess" I posted 3 cams above for 3 different engines. All are the same lobe profile. I've never had an indepth conversation with a lobe but as anyone can plainly see all those cam have the same lobe profile on the cam core for the given engine.
SO, with your comment of each having nothing to do with each other then that lobe must only work in 1 of those engines with your statement since they are not the same.
Old Dec 4, 2014 | 12:37 AM
  #40
gkull's Avatar
gkull
. The super Victor has an operating range of 4000-8000 rpm. .
I don't have exacting information on this SV intake, but I would use one word of caution when talking about intake manifolds. What CI did the manufacturer use to rate this at 4000 -8000 rpm? The answer in the past has generally been 358 ci race motors. 427 ci is @ 20% larger So it becomes a 3200 - 6400 rpm intake.
I'm not claiming exacting figures, but you get the idea. I presently drive around with a plenum volume bigger than a SV and bigger heads than the OP. I never think about some little loss of low end TQ because it is so much greater across the board than any sub 400 ci motor. If you have to ease into the throttle 1st gear of a 700R4 why would you be concerned about gaining some little bit of low end TQ?
Now my 383 uses the weiand 7530 single plane because it is so much smaller
