74 half shaft u joints
Old Dec 6, 2014 | 10:55 PM
MACHEEN's Avatar
MACHEEN
Default 74 half shaft u joints
Help... Replacing half shaft u-joints and got new from o'reilly but they won't push in far enough to get the 2nd clip on. Is there a trick or are these special type u-joints?
Old Dec 6, 2014 | 11:01 PM
thb72's Avatar
thb72
It sounds like your flange is bent. Don't feel bad it is easy to do.
Old Dec 7, 2014 | 12:04 AM
MACHEEN's Avatar
MACHEEN
Was afraid of that. Broke a cap on the first try in pressing one in. No fix for this is there?
Old Dec 7, 2014 | 10:38 AM
thb72's Avatar
thb72
A new one is the fix. Be sure and use a backing plate it helps a lot.
Old Dec 7, 2014 | 04:06 PM
Mooser's Avatar
Mooser
The bent flange is frequently the problem, especially if they have been pressed apart or together without a backing plate, but a couple of other options to consider
What brand of u-joint? The spicer ones (1310x?) are basically right on the top limit for size and are a bugger to install the clips, even if the flange ins't bent. I've had to measure through different clips to find slightly thinner ones to get some to go in properly, even lightly lap a few thou. off here or there.
Is it really close to fitting? If it's off half a groove width the flange may be bent or a roller or two may have fallen into the bottom of the cap and prevent it from going all the way on
M
Old Dec 7, 2014 | 05:56 PM
DUB's Avatar
DUB
M
OPINION:
Hopefully your u-joints are SPICER....and DO NOT have grease fitting in them.
Old Dec 7, 2014 | 06:29 PM
redvetracr's Avatar
redvetracr
I have an extra flange if your interested, still has a u-joint in it. $45 delivered
Old Dec 7, 2014 | 10:39 PM
phat87's Avatar
phat87
2021 C4 of the Year - Unmodified Finalist
Default for what it's worth
I just did my U-joints and posted some inquiries and looked around.
Somewhere I found a post that you use GENTLE hammer persuasion to move the receptacles back toward their original distance.
The other option is to make a threaded screw spreader.
Good luck. It ain't fun when it don't go smooth.
Old Dec 8, 2014 | 05:41 AM
Solid LT1's Avatar
Solid LT1
When installing Ujoints in the outer 1/2 shaft flanges you MUST! Bolt the flanges onto a reinforcing fixture or you can easily bend these parts. Even the splined companion flange can be used if your really talented and careful. The 1/2 shaft Ujoints are Spicer 1350 series joints I will only use HD Spicer parts the don't have grease fittings like GM did when building your Vette.
Old Dec 8, 2014 | 09:45 AM
MACHEEN's Avatar
MACHEEN
Thanks for all you advice.
To 74 half shaft u joints
