This can't be correct
Old Dec 28, 2014 | 11:15 AM
markyerger's Avatar
markyerger
From: You are here to build strength, not demonstrate it
St. Jude Donor '08
Default This can't be correct
Transmission Mount
71, 454, 4 speed.
things did not feel right, so I get under it and start to go over the bolts and nuts.
There are 2 bolts from a tranny bracket to the crossmember of the frame near the exhaust cut outs.
both bolts do not tighten.
I take one out (as shown on the pic)
it appears to be a sheetmetal screw.
Good God, tell me there should be a real nut and bolt here.
Old Dec 28, 2014 | 11:48 AM
Alan 71's Avatar
Alan 71
Hi m,
That's actually the bracket for mounting the shifter.
The mount for the rear of the transmission is forward of the center crossmember.
The bolts are loose because the threaded holes in the crossmember have been stripped.
You can reach through that little access on the bottom of the crossmember and put nuts on the end of slightly longer bolts.
Regards,
Alan
Old Dec 28, 2014 | 12:11 PM
markyerger's Avatar
markyerger
St. Jude Donor '08
thank you thank you thank you for clearing that up
To This can't be correct
