SS Sleeve Calipers
Old Jan 1, 2015 | 10:06 AM
bigjoepos's Avatar
bigjoepos
Default SS Sleeve Calipers
Any way to tell if the calipers have ss sleeves without disassembly?
Are pistons the same diameter - sleeved and un sleeved?
Old Jan 1, 2015 | 10:09 AM
Alan 71's Avatar
Alan 71
Hi b,
The only way to tell for SURE is to disassemble the caliper.
You MAY see a re-manufacturer's stamped logo, number, or date, on the exterior of the caliper if you examine it carefully.
There was no stamped information on the calipers when new.
The pistons are the same diameter.
Regards,
Alan
Here's an example of a rebuilder's stamp.
Gordonm's Avatar
Gordonm
Not really. Some rebuilders stamp a number or letters in them but not all do. The Pistons are the same.
Dang Alan is quick. Beat me to the punch
Old Jan 1, 2015 | 10:10 AM
hugie82's Avatar
hugie82
If you can pull back the piston dust seal, you might be able to see the edge of the sleeve.
Old Jan 1, 2015 | 10:14 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
The pistons are the same diameter. The old calipers are bored out to fit the new SS sleeves which are pressed in. I know of no way of determining if calipers have SS sleeves other than the company doing the sleeving stamping their calipers. I believe Vette Brakes, for example, stamps theirs with VB for warranty purposes, I suspose.
Old Jan 1, 2015 | 10:38 AM
bigjoepos's Avatar
bigjoepos
Got it.
Happy New Year
Old Jan 1, 2015 | 10:43 AM
Jud Chapin's Avatar
Jud Chapin
Same to you and you're welcome.
To SS Sleeve Calipers
