78 C3 misses at mid-throttle
Old Jan 1, 2015 | 02:56 PM
gbarrett's Avatar
gbarrett
Default 78 C3 misses at mid-throttle
I've been working on my wife's 1978 Vette. 29,000 miles, all original except the A/C Compressor. When the car is warm it seems to miss when driving at highway speeds. If I put my foot in it, the miss goes away and accelerates fine but will begin stumbling at mid throttle. It idles fine and when the engine is cool the miss isn't there - only after it is up to running temp. I've already installed a new dizzy cap and rotor. I've tried plugging vacuum ports (to see if something down the line might be leaking) but there seems to be no change.
Any ideas?
Thanks.
Old Jan 1, 2015 | 07:54 PM
DUB's Avatar
DUB
What vacuum ports did you plug????.
AND if you can...post a photo of the engine with NO air leaner on it from each side ...if possible.
How old is the fuel????
Are you sure the timing is correct????
Knowing this is it low miles...have you looked at your spark plugs???
DUB
Old Jan 1, 2015 | 08:11 PM
gbarrett's Avatar
gbarrett
Thanks for the response!
We've been driving the car quite a bit over the last few months. Fuel is fresh, timing has not been changed since we've had the car. The problem "suddenly" appeared about three weeks ago. As far as the vacuum lines, I've disconnected and plugged each line from the carb and intake, one at a time, then drove the car a bit to see if the problem got better or worse. There was no change. Since the car is 36 years old, I did go ahead and order new plugs and wires today. I'll get them sometime next week and put them in.
Unless someone tells me something differently, I suspect that if plugs and wires don't solve the problems (after the dizzy and rotor swap also) that I'm looking at carb issues.
Old Jan 1, 2015 | 08:41 PM
JimLentz's Avatar
JimLentz
Could be the carb or a problem with the heat riser.
Old Jan 1, 2015 | 11:14 PM
lars's Avatar
lars
It's very rare that a carb issue will cause a "miss." A carb can be screwed up really bad, providing an air/fuel ratio of anywhere from 11.5:1 to 15:1 without causing misfire issues. If the ratio is below 11.5:1, you'll see black smoke coming out the tailpipes, but the engine will be "choking" more than "missing." If the ratio is leaner than 16:1, the car will fall on it's face, and you'll get "lean-popping" ("afterfiring," aka, "backfiring") out the tailpipes. If these are not the issues, the misfire is due to ignition problems and not the carb. If you really suspect the carb, send it out to me and I'll check it and test it.
Lars
"90% of all carb problems are ignition problems"
(Quote from my "Tuning for Beer World Tour" Seminar Series)
To 78 C3 misses at mid-throttle
