Lock up convertor operation in a 82??
Old Jan 3, 2015 | 03:07 AM
alconk's Avatar
alconk
Default Lock up convertor operation in a 82??
My question about the lock up convertor in the 82s are under full throttle and around 80 mph if feels like it's locking up and drops a could hundred rpm and you can feel it slow down. I didn't think it would do that under full throttle. Is this correct for this ?
Thanks.
Old Jan 5, 2015 | 11:09 AM
MelWff's Avatar
MelWff
should only engage in 4th gear under cruise conditions.
Old Jan 7, 2015 | 04:10 AM
7T1vette's Avatar
7T1vette
The lockup clutch is only meant to be used during low-power cruising conditions, as mentioned above. When throttle is increased, lockup should drop off (per controller programming) so that the lockup clutch is not damaged.
To Lock up convertor operation in a 82??
