Fuel Line Replacement
Old Jan 10, 2015 | 01:45 PM
Joenski's Avatar
Joenski
Cruising
Default Fuel Line Replacement
I need to replace fuel lines on my 72. I was able to get the old ones out with little issue as they broke into several pieces but the close quarters make it very difficult to get the new ones in without damaging them.
I'm wondering if anyone out there has any tips for the best way to do this other than removing the body
Thanks in advance!
Old Jan 10, 2015 | 05:04 PM
edk136's Avatar
edk136
Remove the body or at least lift the passenger side. I have heard of some people being able to fish the fuel up behind the passenger compartment but I believe the only people that had success, had a removable transmission cross member and was using steel lines that is easier to bend. I was unable to do it and I even had the rear of the body loosened up. So what I did and this will probably ruffle some feathers, I made two junctions for each line. One piece going from the fuel tank to right before the turn down. Second piece going through all the 'S' bends and the third piece going up to the fuel pump. Good Luck
Eric
Old Jan 10, 2015 | 06:26 PM
Mooser's Avatar
Mooser
I had the crossmember off (and drive shaft and rear end and.....) Still a PIA
If you splice in a joint just ahead of the dog leg would be much easier, otherwise, lifting the body a few inches is next best option
M
Old Jan 10, 2015 | 06:35 PM
DUB's Avatar
DUB
If you go through the trouble to get all the bolts out and loose so the body can be lifted....installing the lines in one piece is not that hard. I have done MANY. And I usually do not worry about the transmission crossmember. If it is welded in...I can work the lines through it
In-Line Tubing makes lines that fit REALLY GOOD.
DUB
Old Jan 10, 2015 | 09:39 PM
Joenski's Avatar
Joenski
Cruising
DUB
Thanks for all of the replies! I think I may try lifting the body a few inches first as I'd like to keep the line in one piece. I bought stainless steel lines from Paragon.
Old Jan 11, 2015 | 09:36 AM
edk136's Avatar
edk136
This is the best way to do it if you are willing to try to lift the body. The only reason why I split mine and I definitely would not do this with brake lines is the fuel lines are relatively low pressure lines.
Eric
Old Jan 11, 2015 | 10:35 AM
Joenski's Avatar
Joenski
Cruising
Totally agree. I actually Already did the brake lines. There's a whole lot more room on that side to fish the line plus you're not following the frame up and over the diff.
This is probably a good time to give the body mounts some attention anyway.
To Fuel Line Replacement
