Replacement Battery for '78
Old Jan 11, 2015 | 08:02 PM
Mereness's Avatar
Mereness
Default Replacement Battery for '78
I am looking to replace my battery on my '78 that I just bought. Does anyone have a preference or recommendation of what type, CCA, etc???
Thanks.
Old Jan 11, 2015 | 08:03 PM
briankeery's Avatar
briankeery
Walmart
Old Jan 11, 2015 | 08:26 PM
kcb37's Avatar
kcb37
Depends on what you want.
I go with the highest CCA I can find. Right group battery (will be the right physical size)
Don't remember which one but it should be a 34 or 78. One is side one is top post. Or you can get a side and top post.
Lead acid battery is just fine, they can leak though.
AGM/Gel more vibration resistant, very very unlikely to leak. (they can)
Cost more.
Deep cycle not something you need.
Old Jan 11, 2015 | 09:44 PM
gcusmano74's Avatar
gcusmano74
Just double check that the battery is fully charged when you install it. Sometimes a battery has been on the shelf a while and will need topping off.
Old Jan 12, 2015 | 11:05 PM
TX-Techman's Avatar
TX-Techman
Because of my personal experience with AGM batteries I would recommend a standard battery from store of choice. Watch the warranties, some dealers are only offering a free replacement warranty for 2 or 3 years and no additional warranty. Other still offer a 3 year free replacement plus prorated up to 5 to 8 years.
Old Jan 12, 2015 | 11:55 PM
Indiancreek's Avatar
Indiancreek
The most CCAs as you can find like has been said already.
Old Jan 13, 2015 | 02:11 AM
7T1vette's Avatar
7T1vette
Go to Wal-Mart or Sam's Club (if you have a membership there) and purchase the size and CCA capacity called out in your Owner's Manual. It is just as good as another 'brand'; most batteries are produced by the same factory...just labeled differently. Wal-Mart's warranty is very good...and they will actually honor it, if you do have problems.
Old Jan 14, 2015 | 02:12 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default battery
I buy Delco Professional series batteries for my three Corvettes because of the maintenance I provide they last 8 or 9 years and have replacement for several years longer than most other batteries.
Old Jan 14, 2015 | 02:19 PM
MelWff's Avatar
MelWff
Regardless of what battery you buy check the date code. You do not want a battery that has sat for more than 6 months.
To Replacement Battery for '78
