New carb
To make them perform requires TLC, parts are scarce and your choices are limited.
The numbers just don't say "vette". The truck carb is much cheaper. And remember, since one size fits all, the grand high pooh bah can tune just about any q to any purpose.
$80 will buy you a fairly rebuild comprehensive kit to get you a QuadraJet that will handle the 500hp Lars mentioned earlier.
If I was building a strip-only vehicle, though, I'd be all up on a Holley (if I wasn't going EFI).
In all the hub bub, your original post kind of got hi-jacked.
A couple of things you need to remember.
1. A Q junk may be capable of 750, 800 or on some trucks even 850 cfm. That does't mean they are set up to use it, nor are they even capable of doing it in from the factory form.
"These are a one carb body fits all" carburettor. They were designed to run as lean and gas miserly as possible with stock applications. On a stock car with a new Holley you will be dumping more fuel into the engine. Hence, more power instantly. There are others, but that is the main one.
Will a q junk do that? Sure, but you have to send it to the grand high pooh bah of the q junk to have it tuned. If you do that, you defeat the purpose of the q junk. Why not just get a performance carb from the beginning?
2. You will really begin to notice the changes with your Holley if you change out the intake to a square bore, dual plane like the Edelbrock Performer series or similar.
3. I would not buy a spreadbore carb if you have any plans of upgrading the manifold. You will be severely limiting your choice of carbs. Whether you go with a Holley or not, a square bore manifold can take a huge choice of carbs, the spreadbore cannot.
4. Q junks are not that difficult to figure out. BUT, they are a huge PITA
To make them perform requires TLC, parts are scarce and your choices are limited. 5. I get a kick out of guys who are willing to pay hundreds if not thousands for a "numbers" appropriate q junk carb. For example, the 850 cfm on trucks is the same carb on performance vettes.
Finally, if you keep it stock, the q is probably fine. If you plan to hot rod the car AT ALL, (ie, new manifold) the Holley Streeet Avengert is an EXCELLENT choice.
Not a fan of the Qjet. I have said this many times: The Q jet is GM's attempt to meter fuel precisely through a carb in the hopes of having to forego first mechanical and later electronic fuel injection for its cars and trucks. The earlier mechanical fuel injection was difficult to tune for performance and was expensive-enter the quadrajet. It was generally a one size fits all carb and is overly complicated for what a carb needs to do and does NOT generally improve mileage much. It is a decent carb when functioning correctly but the complicated (for a carb) mechnicals can make them not worth the trouble other than the carb was stock on many C3's. This holy grail nonsense about the Qjet is amusing….
Q-Jets will work well in high performance applications as well, and you can't beat $FREE if you already have one on your car.
; Below is a post that was just posted in another thread where a guy is trying to improve his gas mileage. It is in an 81, but the same principles apply.
I guess my final argument on this boils down to:
"Unless you are like the Grand High Priest Pooh Bah and know how to fiddle and faddle with the Q, it just isn't worth it. Any carb out of the box will perform better than a stock q. And guess what? A whole lot less trouble."
If you want gas mileage, stay stock. Anyone with a 75 thru 81 stocker has a pretty lame sports car by Corvette standards. That would be the primary age of the Q junk.
---Quote (Originally by Patro46)---
Interesting year for fuel mileage issues. I remember this year well. I worked as a line mechanic at Jack Marshall Chevy in Claremore in 81 when the introduction of C.C.C. (Computer Command Control). Looking back, I presume we had to start somewhere, so what better place than to take a Rochester Quadrajet, make a few mods and ad a few solenoids and call it good. Problem is, it wasn't all "that good". Not that it didn't work when properly set up, but we already had issues with the standard non-computer Quadrajets already. Not that either were really bad carburetors, they were just misunderstood by the masses and even earned the phrase "Quadrajunk". This said, when clean (not gunked up) with a PROPERLY adjusted both flavors fared well and delivered decent fuel mileage. Even the original 81 Rochester with it's M/C solenoid and PROPERLY adjusted secondaries carburetors offered decent fuel mileage (tiny primary ventura) and lots of go when a PROPERLY adjusted secondary comes into play. From your description, the first think I'd check is the EGR valve. If that's OK, I'd then check the dwell using a high impedance dwell meter. (Not the timing, but the M/C solenoid). I'd also make note if the hardened steel tamper resistant plugs over the idle air screws have been removed. (Most of the time, the carbs were removed and had a V-notch cut into the edge of the carb base exposing the hardened steel plug). You can also see if the factory cap has been removed allowing adjustment of the MC solenoid. If Bubba EVER got hold of your carb you can bet a T-Bone steak it's off. If your dwell is stuck at 10 deg or lower you found your problem. This was a #1 issue we had, and it continued well past 81 on a LOT of other models. Also, if memory serves me, to set base timing you had to disconnect a lead from the distributor to the ecm before setting the base. A LOT of people would attempt to play with the timing and not disconnect this lead, so the ecm keeps trying to com pensate. In closing, a LOT of people jerked the carb and distributor for a pre 81 distributor and put a Holley and conventional HEI distributor and blocked off the EGR valve, removed the cat and put a test tube in and called it a day. Not that I'm advocating such behavior tho....
Edit... Seems further in the thread you mentioned the computer stuff has been removed and replaced with conventional Quadrajet and distributor. This said, if mechanical issues aren't the case, timing and carburetion are about all that's left. I'd speed the timing up until it clatters, then retard it to just where it doesn't (under hard acceleration) Good Luck!
The Holley on my Ford F-250 ran like crap compared to the Q-Jet I have now. So by that logic, Q-Jets are better.
The E4ME is an even worse example, because there are archaic computers added to the equation. In working condition, the E4ME actually runs really well.
All of these carbs are also saddled by the late 70's ignition theory (ported timing, next to no mechanical advance, tons of vacuum advance), rudimentary emissions controls (EFE, EGR) puny compression ratios, etc. It's easy to see why the carbs that sit on top of them get a bad rep.
I've torn a Holley (mech sec) to bits and put it back together, and it amazed me at how easy it was to do. A Q-Jet is stressful the first time. After that, I can have it torn down and back together in under an hour.
I will gladly cede that without ever having touched a Holley, I could tear it down and put it back together in about 20 minutes. My first Q-Jet was probably 3-4 hours with a lot of reference material.
But I also prefer my USP, which is mechanically complex but more comfortable in a lot more situations versus a 1911.
Going to have to deal with some serious warpage of the air horn and main body though, I am taking a good look at the de-warping method Reelav8tr posted last September.
If I was delivered a car w/ a Carter/Edelbrock on it, BUHBYE. It'd get replaced w/ a Q-Jet merely because I have a small selection of good used cores and a fairly strong understanding of Q-Jets. So, for $80 I could have an excellent running Q-Jet, can't (easily) get a Holley to replace it that cheap. Holleys are easy to work on but frankly I have very little knowledge of tuning Holleys and am way down the field w/ learning Q-Jets.
Lars is a ridiculously great option though... people have paid more to do less, that's for sure.
I agree with your point, though. If it's inside your comfort zone and you're not willing or interested to learn something else (not trying to imply it's a bad thing), I can see sticking with something. I don't know if I'll have an opportunity to learn Holleys, but if I had the opportunity I'd take it. I almost took on an Edelbrock project for someone as well, just to learn.
20 years ago I bought a custom Carb Shop Q-Jet for like $450.
It was NEVER right. Countless things done wrong.
A week with Lars (for pretty-much peanuts) and this thing shreads.
My old 68 L36 is a blast to drive. Don't hit it hard in city streets.
