I looked back on past post but couldn't find what I was looking for so here goes. I am putting a new Holley Street Avenger carb on my 79 L82. I want to leave the stock intake on for now. The new carb needs an adapter plate to convert to square bore which I now have both carb and plate but I am not sure if it will fit under the stock L82 hood. I have found that with the electric choke I can only use a 7/8 drop base air cleaner. Will this combo fit under this hood. I am also thinking of putting an L88 scoop on. Any past experience anyone has would be a help. Thanks
Have you already purchased the Holley? If not recommend the 650 Holley 6210 double pumper. Do not have to use a spacer on your intake, spread bore design. Have used the 6210 650 double pumper since 1974.
One of my friends has 3 corvettes and has put holley carbs on each one and has noticed a great improvements with his cars. I have great confidence in his ability. All of his are under high rise hoods though which mine doesn't have. This guy has no faith in Q-jets but after riding in his and then mine I thought that it might be just the trick for mine.
It's not the trick if you have to use an adaptor and have hood clearance problems. You should do some more research on this site concerning the Quadrajet.
In my previous post I commented on Q-jet carbs as described to me by a really good friend who has had them for many years. I am not trying to start a debate. I am trying to tap into the experience on many of you who have way more knowledge than I so please don't take this the wrong way as I am looking to gather info to make a better decision. Thank you
I really like the looks of an L88 hood even though is isn't stock for a 79. I may purchase an L88 hood which I know will work well with the carb I bought.
No debate here, I have an old Holley 3310-1. The difference is I dont use an adaptor, have an Edelbrock RPM Air Gap and an L-88 Hood. Just cannt see you going through this change without doing it correctly. Since it sounds you have already purchased everything can you measure your current hood clearance with some soft modeling clay and judge from that?
Sounds like your friend took the easy road instead of learning about qjets. Do your research and you'll learn that a Holley does not have any HP advantage over a Qjet.
Most of my friends who drove the hell out of Holleys say my car drives like it's fuel-injected.
It's not, and I don't think it feels that way, but I have very little incentive to switch out my very well running Q-Jet (my combo made 450hp/484tq on an engine dyno) for a Holley.
I wuld send your QJet to Lars, havevhim go through and let you know what is required. Ask him for his tuning papers as well. If you are hell bent on a Holley he'll suggest one that will work very well with your combination and what jets to use.
I'll second what the others are saying about a good Qjet. But at the very least go buy a good used performer squarebore intake, (they're everywhere ), or use a spreadbore holley on your intake.
Set an adapter on top of your stock intake and see the mismatch of where the throttle plates will be positioned !
Lots of folks like the Qjet. They are great as long as they run correctly but can be problematic since they are overly complicated for what a carb needs to do-GM's attempt at precisely metering fuel through a carb. GM stuck with the Qjet for way too long when others switched to mechanical/eletronic fuel injection. I have used a Holley 4175 650 CFM vacuum secondary Q jet replacement with the stock L-82 aluminum intake for 30 years. Carb has been perfect...
I don't believe you will have an issue. But it doesn't hurt to check. You can lay a ball of play doe or clay, or silly sand, or something like that on top of your air cleaner and close the hood to measure your clearance.
Good choice on the Street Avenger. Excellent carb. You will enjoy much better performance.
You may need to change to a manual kick down and get rid of the smog computer.
Gordon -
Where have you been..?
There's no smog computer on a '79. Holley carbs can be easily fitted with the lower stud to make the TH350 kickdown cable work - you just have to install one of the many available aftermarket throttle cable brackets.
Seacoot -
Please send me that old, obsolete, used out, not made anymore, non performance piece of crap Q-Jet when you pull it off. It's one of the 800 cfm high performance carbs that will easily support 550 horsepower. It's no good for you. That little 670 Street Avenger is just the ticket... fer shure. I will pay shipping. Please e-mail me for my shipping address.
When I signed on to this forum I had done a lot of reading here first. I was hoping that it would be fun and great place to learn. Also an opportunity to bounce ideas that others in my area are sharing with me to get a sense of what will or will not work. I did not expect a sarcastic response like the one from Lars. This is no place for me. I am sure there are other places with people that don't act like Idots as Lars does. Signing off
This man is right on the money
Theres some nice Holley based stuff out now but with the cost/space issues I honestly feel youre going backward$ here.
Get angry with your 'friend' that gave you bad advice, not with the people that are trying to help.
You completely misunderstood my post. I wasn't taking sarcastic jabs at you: I was poking fun of Gordon. Gordon and I have done that for years on the Q-Jet/Holley issue, and it's all in fun. I provided you with some factual info on the Holley conversion in my post. The rest of the post, although directed to your name, was just me sparring with Gordon. You don't have to go away...
