Freeze plug question?
Old Jan 22, 2015 | 10:59 AM
jimvette999's Avatar
jimvette999
While tempting, you never want to use a driver that fits inside the plug or you're asking for a leak as it will create a cave in effect. Maybe to just get it started worse case then use a driver equal to, slightly less than the O.D. of the plug. Coat the outside with "High Tack" by Permatex, not a slippery silicone. Also, what about freezing the freeze plug, to shrink it ever so slightly.... I won't suggest heating up the block with a torch in the area of the install to expand that area.
Jim
here's a post I found in another forum that supports my claim of warning for those that think I'm full of it
http://www.hotrodders.com/forum/what...ml#post1363783
