Ive had my 77 for about 2 weeks now. After going thru and doing some maintenance and tune ups I was going to get a valve job. Pulled the heads and found a messed up cylinder. Went to a local shop to get some prices. The guy said he knew of a full 454 for the same price itd cost to machine it. Jumped on it for only $350. Its all stock from intake to oil pan and flexplate to water pump, including exhaust manifolds, brackets, and gaskets. After researching, everyone says that Ill need new exhaust, pulleys, brackets, and springs. What is the best budget headers? Do block huggers hook straight to the exhaust pipe? For the pulleys and brackets, since I have the original brackets do those fit or are there different ones? Do the pulleys or the fan from the 350 fit the 454? Springs are last one the list, but Im not sure what to upgrade them to.
Headers- Hedman 2", painted, jegs/summit = $250
Springs- O Reilys auto sells Moog big block replacement springs= $69
Small block brackets and pullies will not work on the BB. You can buy all that stuff new (repro) from the Vette parts vendors, but get ready to pay...it ain't cheap. You'll spend $1k easy on repro brackets/pullies.
The fan should work from the 350. (7 blade with thermal clutch).
You'll have to have new exhaust ran to connect to the headers.
This swap is not as cheap as you think it will be. It is worth it if you want a big block, but definitely not budget.
Junk yard/swap meet/ebay parts can help you keep the cost down some.
I made the swap, I bought all new/repro stuff, I spent a fortune... But I love it when I pop the hood and see those fat valve covers.
I read that the brackets and pulleys were expensive, but are the original 454 brackets ok to use? I pulled the A/C so thats not included, but can i use the same alternator and power steering ( just with new pulleys). I was going to try to match them up and see if they fit (crank pulley too)
I didnt exactly mean budget, lol. Although I do want it kind of cheap so I can drive it for now. I have another 454 that Im building but thatll be awhile before I get it completed. This is more to have it ready for a big block when the time comes.
I used my 350 engine mounts, upper rad hose, starter.
I tried messing with the 350 pulley's but had clearance problems. I have seen much cheaper repos on line that i would like to investigate
My springs had been upgraded to 460lb during my resto and I just swapped in a new Dewitts rad so no cooling issues
My 454 has Aluminum heads, intake, water pump so the weight isn't too much more than the 350
Like they say it wasn't cheap but its going to be a blast!
That looks real good. I didn't even think about the starter, good to know it fits. I found a pulley set for about $150 so that seems better than trying to make the old ones fit. I plan on a new rad and thinking about electric fans, but that can wait a couple months(unless it cant take it), but does the fan fit under the stock fan shroud? Your air cleaner looks like it sits kind of high, does it fit under the stock hood or did you replace it?
Hi, I did the swap in my 77 and went with the Dewitts radiator too, works great.
I used a long water pump with the alt on the right
side. Plenty of room to work with the ps of the left. I like it, lots of fun and it all fits under the stock 77 hood. Good luck with your swap.
my fan was just touching the rad so i put a flex fan on to get it running. I find the flex fan is too noisy and sounds like a dump truck reving at 10,000rpm so i'm going to find some bbc pulley's and put the stock clutch fan on. For the fan shrould i removed the extension that was on mine.
I am running a performer intake on mine , drop base air filter, Qjet & 3" filter element was hitting the hood. Changing to a 2"X 14" element the hood closes.....i'm still playing around with it and just changed to a Quick Fuel 750 carb
Mines an automatic. It was a stock L48, but it seems that Bubba had some fun with it. I had an Edelbrock Performer intake and a Holley 650 carb and I couldnt fit in a stock air filter. I was worried about having the same problem on the 454, but the intake looks lower.
What kind of headers did you use?
John65, that looks awesome.
Looking at these just makes me even more excited. You guys are great. Thanks
I used the painted steel 2" Headman headers. I had to massage them a bit on the right side by the frame rail and they are a snug fit by the steering box...not sure if my fitment issues is due to raised exhaust ports on my aluminum heads.
The rest of my exhaust consists of the factory 2 1/2" with stainless Magnaflow mufflers, has a nice rumble but not excessive for cruising
Is yours Automatic or 4 speed?
Could you post a picture of your radiator and fan setup?
If the engine you bought is stock, your compression will be something short of 8:1. At least get that taken care of an install a decent cam before you drop it in or you'll get tired of looking at smallblock car's tail lights.
No need for 2" headers, either - 1 3/4" are plenty for up to around 650hp. Headers that are too large don't scavenge nearly as well due to lower velocity.
It's possible to use early 90's smallblock serpentine brackets with adapters, probably the least expensive route.
This was taken when the 350 was still installed. When i swapped in the 454 I removed the extension on the fan shroud
Dewitts direct fit
This is with 350 pulleys shimmed to fit. I'm worried about balance issues and don't like the noisy fan so i'm going to find proper bbc pulleys and use the stock fan
I did a 468 swap on my 74 a while back and I came across a lot of things people did not mention needed to be changed (or made...depending on how you approach things)
I did not get to read all the posts so forgive me if I am repeating any information. IIRC you will need:
Pulleys/Belts
Water pump (different shaft size)
2 Power steering hoses (can't remember which 2)
Radiator is different but if you're not upgrading the motor the stock small block one will do temporarily
Wiring is different but can easily modify the stock harness
Fuel pump is different but will be fine if you're not pushing a bunch of power
I cannot speak for ac or emissions because I deleted both of those.
I know I'm missing a few small things but I hope that helps
I already ordered the pulleys so I guess the serpentine is out, lol. Still looking for headers and its a toss up between shortys and block huggers. Im looking at cams and there are sooo many to choose from. I was looking at a Comp Cam Thumpr, anyone familiar with it? They seem to emphasize the idle and not so much the power.
I had a 383 sb built and hated it, I swapped it for a 454 that has oval post heads and perhaps a mild cam, auto tranny,
We swapped the 383 out and the 454 in and I drove the car home 100 miles the next day...hard? nope....
So far Ive ordered the BBC long water pump pulleys and a set of shorty headers. Am I correct in assuming that if they fit a '73 with a big block it should fit fine in a '77? I dont have an air pump and removed the A/C compressor, so with that setup I think the alternator is on the pass. side and P/S on drivers side, but Im having a real hard time finding the V-belts. After looking at comp cams I found the Xtreme Energy cam kit that fits well with the stock motor/torque converter, and has a rough idle.
That and new main/rod bearings and rings for peace of mind, and I think Ill be ready to put it in.
I did a bbc into my 76 and on a bologna budget. I stuck with doing the corvette style of the Alt. being on the drivers side, and used all brackets and pulleys from late sixties bbc's and sticking with the short water pump. I went electric fan and that made it even easier. All and all, I only spent about $500 for the conversion. That's even including the Rad. Now when it came to the vbelts. I actually measured and tried about a dozen till I got it right where I wanted it. So you might have to do the same.
Reason: add
