Rear end service 76
Old Jan 21, 2015 | 01:08 PM
calvette 11's Avatar
calvette 11
Default Rear end service 76
I'm greasing the rear axle bearings on my 76. The book that I have states the spindle flange bolt is to be torqued to 100 lbs.
I put this together 15 years ago. I don' t think they were this tight..
Does anyone know the tight ness of this bolt
Old Jan 21, 2015 | 01:44 PM
MelWff's Avatar
MelWff
that number sounds correct
Old Jan 21, 2015 | 08:36 PM
'75's Avatar
'75
Old Jan 22, 2015 | 06:55 PM
DUB's Avatar
DUB
ACTUALLY...90 lbs/ft and then tighten further to align up the castle nut so the cotter pin can be installed.
You are aware that you are only greasing one bearing? No way to get grease to the outer bearing unless it is disassembled.
DUB
To Rear end service 76
