Diamondback Redline Tire
Old Jan 24, 2015 | 12:47 PM
SoCalErv's Avatar
SoCalErv
Army
Default Diamondback Redline Tire
Does anyone have some good pictures of the Diamondback redline tires they could post? It is my understanding they valcunize the 3/8 inch redline to a modern tire, in this case it would be BFG TA 245/60R15.
Before I spend the dollars I wanted to see what they really looked like. Would not like them if the redline portion looked out of place.
Thanks for any help.
1969 Corvette Tires
TREAD SECTION
SIZE MFG HEIGHT WIDTH WIDTH
F70/15 STOCK Goodyear 26.5 6.5 8.95
205/70R15 Michelin X 26.3 5.6 8.2
215/R70R15 Michelin X 26.6 6.8 8.7
225/70R15 BFG TA 27.4 7.2 9
235/60R15 BFG TA 26.1 7.6 9.5
245/60R15 BFG TA 26.8 8.2 10.2
Closest to Original Tire
Height - Fill tire well 215/R70R15 Michelin X
Tread Width 215/R70R15 Michelin X
Section Width 225/70R15 BFG TA
Old Jan 24, 2015 | 12:55 PM
SoCalErv's Avatar
SoCalErv
Army
Sorry about the formatting. Everything was fine as I typed and then skewed when saved, go figure.
Old Jan 24, 2015 | 01:19 PM
Alan 71's Avatar
Alan 71
Hi SCE,
In reading about the Diamondback tires it seems that the 'dimples' (sometimes 2-3-4 per tire) that many new tires have really bother some people.
It appears the 'dimples' are much more noticeable after Diamondback has done it's magic because the sidewall is so plain.
So?
Regards,
Alan
Old Jan 24, 2015 | 03:04 PM
SoCalErv's Avatar
SoCalErv
Army
Thanks - I would not be happy with dimples or whatever we call them in the sidewalls. Besides that they look pretty good.
Is the dimple a every tire issue?
What causes a dimple?
Old Jan 24, 2015 | 04:16 PM
ddawson's Avatar
ddawson
They seem to be on most lower rates speed tires.
My Outback with continental tires has two on each tire. My kids Mazda 2 that came with Toyos had them but the BFG KDW2 do not.
Both of my other cars that have Goodyear Eagle Asymmetric 2 are fine. Also my RX7 with H rated Sumitomo tires also has a dimple on each tire.
Old Jan 24, 2015 | 05:36 PM
std1940's Avatar
std1940
Default Very happy with DB redlines
I have had my DB redlines for 3 years .
Mine have no dimples.
They look and perform great!
Mine are the BFG radial t/a 225/70/15
Tom.
Old Jan 24, 2015 | 06:28 PM
ajrothm's Avatar
ajrothm
Erv,
Diamondback offers a BFG Radial T/A with smooth sidewalls (no lettering)and any color stripe you want. They shouldn't have the dimples. We are about to buy a set of these in Goldlines for the 65'. They are around $1k shipped.
I wouldn't use the cheesy passenger car tires that DB offers. Your Vette will drive 10x better on BFGs then your current bias ply redlines.
A great tire size is 245/60/15 front, 255/60/15 rear.. Unless youre trying to keep it completely stock looking, then you will need a 225/70/15 I believe.
Old Jan 24, 2015 | 07:47 PM
SoCalErv's Avatar
SoCalErv
Army
Originally Posted by ajrothm
Erv,
I know how the 245/60/15 tires handles, like your on a track. I wonder how the 225/70/15 would handle?
Anything is better than these nylon tires.
Old Jan 24, 2015 | 10:09 PM
ajrothm's Avatar
ajrothm
For no harder then you are going to push your car, the 225/70/15s will be fine. They are about 27" tall which is real close to the stock tire height. They will have a bit more body roll then the shorter 245/60s(26") but they will fill the fenders better. A 225 will be a bit stretched on 8" wheels but, that's how they looked from the factory with the F70s so... You'll mimick the stock look well and have a good performing tire.
Me, I like a little more meat on my plate so... I use 245 fronts and 255 rears most of the time. Now I run 275s on the rear that really fill the fender well. But when my car was stock, the 245/255 combo was great and the tires fit the wheel width correctly.
Old Jan 24, 2015 | 10:21 PM
CVO2FIXUP's Avatar
CVO2FIXUP
What year car do you have? And did you have any tire rub on the front with the 245? Thanx
Old Jan 25, 2015 | 01:33 AM
ajrothm's Avatar
ajrothm
Mine is a 71'. No tire rub with the 245/60 on the front. Not even close. A 255/60 on the front MAY rub.. Plus it's taller.
I feel the 245/60 is the perfect size for the front to fill out that 8" wheel.. But at 26.5", it's slightly shorter then the stock F70 tires. My car is about 1" lower then stock so they are perfect for me.
To Diamondback Redline Tire
