Strange Headlight Problem
Old Jan 25, 2015 | 03:05 PM
Griff2002's Avatar
Griff2002
Default Strange Headlight Problem
I just replaced the headlight switch and decided to check the lights before I buttoned everything up. Here's what happens:
Low Beams: Only passenger side comes on
High Beams: All four lights come on as they should
So clearly the driver low beam lamp is ok, but why would this one only come on when I turn the high beams on? I'm thinking it is not an issue with the new switch because the passenger low beam works as it should.
I did not check the lights before I started the project, so perhaps this problem existed before I replaced the switch. I suppose I could put the old switch back in and see.
Old Jan 25, 2015 | 03:09 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Try swapping the bulbs first to see if it's a bulb problem.
Old Jan 25, 2015 | 05:45 PM
wombvette's Avatar
wombvette
Two filiments in that bulb. One is burned out.
Old Jan 25, 2015 | 05:55 PM
'75's Avatar
'75
Old Jan 25, 2015 | 06:34 PM
Griff2002's Avatar
Griff2002
Originally Posted by '75
I had (incorrectly) assumed there was only one filament since there are separate high and low beam bulbs. Learning more every day. Thanks for your help.
Old Jan 25, 2015 | 06:54 PM
'75's Avatar
'75
The outer bulbs have a low beam filament and a high beam filament, the inner bulbs only have the high beam.
To Strange Headlight Problem
