Helpppppp!!
Old Jan 25, 2015 | 10:31 PM
VETTE N ME's Avatar
VETTE N ME
Default Helpppppp!!
Well while chasing a no courtesy light issue in speedo or console I was attempting to lower my steering column to get access to instrument cluster and one of the nuts broke loose on the bracket where the two bolts holds the column up, so now the bolt just spins freely. Anybody ever encountered this problem and have a solution. I didn't realize how rusty the bolts were. Also could you all help me with the blowing of the clock/lighter fuse which is also for the courtesy lights. What all does this fuse control? Thanks in advance!!
Old Jan 26, 2015 | 06:56 AM
VETTE N ME's Avatar
VETTE N ME
Anyone?
Old Jan 26, 2015 | 07:37 AM
zuendler's Avatar
zuendler
You mean the bolt is still in place, and spins with the nut on the upper side?
Well, in this case you have to cut the head of the bolt or try to drill it out while someone is holding the bolt with a wrench.
Old Jan 26, 2015 | 08:46 AM
Alan 71's Avatar
Alan 71
Hi V,
Ugly!
Have you tried to reach the nut yet?
On my 71 it's a square nut, not hex.
I can just feel it with my fingers.
I guess I'd begin by trying to soak the bolt and nut with WD40 while trying to figure out a scheme to get a wrench of some sort on it.
I'm not sure just how later dashes are assembled?
Is it the nut the one on the outside of the column, or the one towards the center of the car?
Regards,
Alan
Old Jan 26, 2015 | 09:43 AM
VETTE N ME's Avatar
VETTE N ME
Yes the nut broke loose from the bracket and just spins. I tried to put a socket on it but could not find the right size. Thanks for your response!!
Old Jan 26, 2015 | 09:49 AM
VETTE N ME's Avatar
VETTE N ME
Originally Posted by Alan 71
Hi V,
Ugly!
Regards,
Alan
I soaked the bolts with PB blaster. The nut is toward the center console. So the nut is square? I thought it was a hex. That's why I could not get a socket to work. I will try to get a wrench up in there. Thanks for your response!!
Old Jan 26, 2015 | 10:26 PM
VETTE N ME's Avatar
VETTE N ME
I cut the head off the bolt and got the column down.
Old Jan 26, 2015 | 11:06 PM
Jim Shea's Avatar
Jim Shea
Now that you got the steering column down and out of the way you should be able to unbolt Plate (C) from Bracket (A). Then have someone reweld the loose nut back on the plate.
Jim
Old Jan 27, 2015 | 05:26 AM
Cavu2u's Avatar
Cavu2u
Jim
Vette N Me,
I understand it's a square nut that's tack welded into Plate (C) and Bolt (K) screws into it, No?
How/what did you use to cut that bolt head off?
Steve
Old Jan 27, 2015 | 03:40 PM
VETTE N ME's Avatar
VETTE N ME
Originally Posted by Cavu2u
Vette N Me,
Steve
I used a cutoff wheel on my drill. The square nut is still on the cut bolt. So I will have to put a bolt, washers and nut to hold the column back up.
Old Jan 27, 2015 | 05:52 PM
Cavu2u's Avatar
Cavu2u
Gotcha. I had to do something similar is rebuilding a seat pan.
Steve
To Helpppppp!!
