4 link/ moser
Old Jan 26, 2015 | 08:45 AM
bap's Avatar
bap
Default 4 link/ moser
Corvette c3 1980
Old Jan 26, 2015 | 10:33 AM
tyancey00's Avatar
tyancey00
Very nice, said the guy with the whole rear end out of his car....
Old Jan 26, 2015 | 09:13 PM
JoeC427's Avatar
JoeC427
Old Jan 30, 2015 | 03:30 AM
bap's Avatar
bap
Now its on
Originally Posted by JoeC427
Old Jan 30, 2015 | 08:23 AM
roger3's Avatar
roger3
Originally Posted by bap
Now its on
Looks great. Did you have to rework the tunnel and or floor to fit it?
We need details, what class you gonna run, how fast you shooting for, and what motor and tranny?
Roger
Old Jan 30, 2015 | 03:31 PM
tektrans's Avatar
tektrans
Nice so far. The 4 nuts and bolts coming through the rear compartment area in the 2nd pic looks to be bolting down a nitrous bottle bracket to me. I see the roll bar welded to the frame in the first pic, Not to mention the th400 trans with an sfi approved bell housing sitting on the floor. Hmmmmmmmmm
Old Jan 30, 2015 | 04:15 PM
tektrans's Avatar
tektrans
From the pics it looks like you are still a ways away from the car sitting right and the tires fitting right also. What are your plans?
Also how did you mount those rear shocks-I cant see the brackets or bolts-did you go through the frame and bolt from up top?
Old Jan 30, 2015 | 11:34 PM
JoeC427's Avatar
JoeC427
Install looks badass. What gears do you have in it? It looks like you have a 275 Drag Radial under the car. Did you get the set up from AutoFab? That is exactly what I want to install in my car. Interested in coming to Florida and installing another one???
Very Nice Man!
Joe
Old Jan 31, 2015 | 12:13 AM
tektrans's Avatar
tektrans
Damn Joe-with a hood like that you GOTTA get your solid axle in the car!!
Old Feb 1, 2015 | 08:33 PM
JoeC427's Avatar
JoeC427
I agree. Just finished the install of the 582. I am making custom length plug wires because the Moroso super 40's we used to dyno the motor won't work with the corvette headers. I would like to put a 325 drag radial with no-fender flairs tucked under the rear. Next step is to update the cage to get it certified to 7.50. Not to steal this post. Bap's install looks perfect. I really like how the Moser housing fits under our c3's.
Take care,
Joe
Old Feb 2, 2015 | 03:03 AM
bap's Avatar
bap
hI Yes i did go through the frame to get it 1 " higther up !
Engine ls 9 ported heads other cam 15 psi boost bigger intercooler nitrous, transmission " lentech " ford AOD .... FAST XFI
i will post more pic when i asamble it ... littel by littel...
Brian
Old Feb 2, 2015 | 03:06 AM
bap's Avatar
bap
Very Nice Man!
Joe
Hi Joe ,,
Yes i come to florida and help you
it is so cold in Denmark now ... - 15 degree by nigth ,yes it from autofab
Old Feb 2, 2015 | 03:39 AM
bap's Avatar
bap
And the" tunnel do NOT fit have to do a lot of fiber work....
Transmission gears 3.50 hope it is ok ! ? i had 3.73 before but it ran out 300m out !...
Old Feb 2, 2015 | 08:12 PM
tektrans's Avatar
tektrans
What are you going to do for an anti roll bar?
Old Feb 2, 2015 | 08:52 PM
JoeC427's Avatar
JoeC427
Hi Joe ,,
Awesome! Best of luck. Looking forward to seeing more pictures.
Your going to kick some but with your Vette in Denmark!
Old Feb 3, 2015 | 03:57 AM
bap's Avatar
bap
Do not know yet !
Old Feb 3, 2015 | 04:51 AM
bap's Avatar
bap
Roger
Engine ls9 ported heads other cam 15 psi boost bigger intercooler nitrous,
This transmission i the best ting i ever have done ... no more transmission problems... and its is a overdrive ... ..
Class " daily driver Hope to come under 10 sek
Brian
To 4 link/ moser
Old Feb 11, 2015 | 03:19 AM
bap's Avatar
bap
new cam + springs ..
Brian
Old Feb 11, 2015 | 07:32 PM
JoeC427's Avatar
JoeC427
Re you planning 10" wide rims and Drag Radials? If so whet size rim/offset are you planning, and what size tire> I'm trying to figure out what is the largest tire you can fit under the stock wheel well with the AutoFab kit.
Old Feb 13, 2015 | 03:29 AM
bap's Avatar
bap
Fuel cell pump filter ,almost complete, the intercooler pump missing
If anyone has any idea to do it better or if I'm doing something wrong .... please tell
