Distributor advance curve
Old Jan 27, 2015 | 04:43 AM
Haggisbash's Avatar
Haggisbash
Default Distributor advance curve
Hi, does anyone have a copy of the mechanical and vacuum advance curves for the distributor for 70 base model 350?
Old Jan 27, 2015 | 07:47 AM
Revi's Avatar
Revi
Are you aware that you can make adjustments to the timing that will work better than the original factory settings?
Old Jan 27, 2015 | 12:42 PM
7T1vette's Avatar
7T1vette
The curves are approximately linear from (the RPM) where the mechanical advance starts to kick in and until it maxes out at the positive stop. All distributor curves can be modified by altering/swapping weights, retention springs, and stop collars.
Binding and/or mechanical restrictions in the advance mechanism can yield "odd" advance curve behavior and need to be resolved before trying to establish a new curve.
Old Jan 27, 2015 | 06:45 PM
Haggisbash's Avatar
Haggisbash
Thanks for the info. guys. I have already had a few goes at the advance springs in the dist and it seems to be running reasonably well (static advance about 15 deg, full advance 35 deg at 3000 rpm) except I believe that the vac advance is too much at idle (running manifold vac) because the idle is quite uneven unless you disconnect the vac advance, there is also some popping from the exhaust when descending hills unless I make the idle mixture richer, say about an A/F ratio about 12.3 to 1, I think this is too rich. Sitting at idle with the car in drive she does idle smoothly though. Was thinking of changing the vac advance can but my eyes were glazing over trying to figure out what to use!
So, I found an electronic unit that can replace both the mech and vac advance, will retain the stock dist (I have already rebuilt this)and can be programmed with several curves, I figured maybe this will be the answer as I can tailor the curves exactly to what the engine likes but retain a stock look.
Hence my asking for the original timing data because I would use this as a baseline if I get one of these units.
Old Jan 28, 2015 | 07:22 AM
7T1vette's Avatar
7T1vette
If spending money is no problem, go for it. Otherwise, the vacuum advance cans are for different amounts of advance at idle vacuum. You need to know what your idle vacuum is and how much total advance you want from the advance can to make your selection. It sounds like you already have that info.
There are also "adjustable" vacuum cans that allow you to tailor that device to your particular needs. Lot less expensive (and less trouble) than figuring out a new spark box, too.
Old Jan 29, 2015 | 10:21 AM
glen242's Avatar
glen242
Lars has a paper(s) listing vacuum can specs by numbers.
E-mail him for a copy.
Old Jan 29, 2015 | 10:29 AM
7t9l82's Avatar
7t9l82
i agree get a different advance can. probably about 10-12 degrees.
To Distributor advance curve
