ECM Issues with an 82
Well fluctuating timing is 1 of 3 items.
1 - distributor
2 - dampner is slipping making a false timing change while timing is still good and problem is somewhere else
3 - ECM is having problems controlling timing
No DTC and engine running wild means ECM is doing poor job.
U could check the O2 output as it sound be 0 to 900mV with closed loop stoichiometric 14.7 a/f reading or trying to control near 450mV.
O2 indirectly controls the fuel trims so if mixture swings wildly i would look a the O2's output.
Pull the dist look it over for loose or frozen parts - hey even new dist can be goofed and get through quality control. I dont think your dist has weights though as the ECM controls advance i think. Check dist shaft play. Look over dist cap and rotor - ya know its easy to clip on the cap at the wrong position.
BTW what did u do for a ECM/chip tune with the new build - heads, cam, intake? Your engine vac maybe much lower now than stock and the ECM maybe correcting. Im thinking a speed density system here with absolute pressure used for MAP/vacuum telling ECM what engine load is. Dont know what your ECM VE map looks like or is but your VE has definitely changed.
1 - distributor
2. Balancer was replaced last year, double checked mark against tdc when rebuilding, it was spot on. Double checked again when issues started, still spot on.
3. ECM is what I'm thinking. I've replaced everything else. Balanced TBs, re installed intake (Renegade), fuel pressure confirmed at 14 psi even under load. Definitely running rich, you can smell it, running a three wire O2 sensor that will get replaced soon to eliminate it as a cause.
Dist is ECM controlled, no weights. All wiring good, no undue shaft play, cap is on correctly and locked down, timing set at 8* with EST unplugged. Timing varies wildly with knock sensor connected or disconnected, you can watch is moving at idle, when you blip the throttle it retards timing, then advances, then retards etc.
ECM tune is PO installed Hypertech chip, not the ThermoMaster, but the other one. It was running like a champ until the new year. Something I noticed was a bouncy tach, I hear tell wacky tachs can affect HEI, so I'll bypass the filter to see if the tach steadies, and if it does I'll get a new filter, if not I'll get a new filter and a new board. Also going to feed a 5v signal to the ESC input on the ECM to see if that corrects the wacky timing. If it does, I'll need a new ESC module, if not, then the ECM is the culprit. Personally I'm hoping its the bouncy tach, that's the cheapest fix.
EBL Locker system is coming up. I want the ability to tune the motor beyond what the stock ECM can do. The cam I chose for this build is really mild, Voodoo 256/262 with 1.6 roller rockers, I expected some learning to have to happen, but the ECM should have been able to handle that cam. It has 112* separation, so it should play nice with the stock tune and has been until recently.
The good news is I have time to figure all this out and fix the issues. I was under the gun because I didn't have a backup vehicle, now I do so I can relax a bit. The vette wasn't supposed to be a daily, but my daughter turned 16 last year and I've been letting her use the other car. I just got a great deal on a pickup truck so now I have time to figure out the issues without a time constraint or transportation logistic issues. Keep the ideas coming! And thanks for the compliment!
BTW Howell Engine developments has some good pricing on TBI ECM systems - u may want to contact them with your problem also: http://howellefi.com/gm-tbi-products...cessories.html.
I use WinALDL to datalog the motor and ECM. Unfortunately I can't see timing events very well, although knock counts and O2 voltages are very visible. I'm with everyone else thinking O2 sensor. Will that affect the timing though? I know it will affect fuel. My current O2 is a GM three wire (due to the headers) and as stated I'm not seeing any codes. Cardo go look at the EBL site (dynamicefi). The dataloging software that comes with that system is pretty good, monitors lots of parameters and the speed of the ECM is much better than the stock ECM i'm running.
As far as O2 affecting the timing i dont see how that happens either. Timing is more affected by the MAP, rpm and the knock sensors.
BTW Howell engineering has a TBI trouble shooting guide for only $12 - u may be interested: http://howellefi.com/tbi-service-manual.html
Good luck dude.
Good luck dude.
Good luck.
Check Engine light went off for at least 15 sec = faulty O2 sensor or connector.
Check Engine light flashing = Open loop, open O2 wire circuit, faulty ECM or ECM connector.
The Chiltons "Fuel Injection & Feedback Carburetors 1978-85" has a diagnostic flow chart for each circuit. Too much for me to type. Amazon still has them in paperback:
Hope this helps, good night.
