Old push button relay on firewall
Old Feb 7, 2015 | 07:47 AM
RETIRE15's Avatar
RETIRE15
Default Old push button relay on firewall
IT LOOKS LIKE A RELAY OF SOME KIND ,WITH A BUTTON THAT SAYS START. NOT HOOKED UP BUT STILL BOLTED TO THE FIRE WALL ,WONDER WHAT IT WAS USED FOR
Old Feb 7, 2015 | 08:11 AM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
If it is on a 74 it sounds like the the seat belt interlock override. It was a one year only feature and would allow you to start the car without the seat belts fastened.
Old Feb 7, 2015 | 08:14 AM
RETIRE15's Avatar
RETIRE15
You know what ,your right i seen one on line just like it ,thanx dan
Old Feb 7, 2015 | 10:31 AM
Peterbuilt's Avatar
Peterbuilt
Default Hi again.
dan1495 is correct.
See pages 12-43 and page 12-62 in your 74 GM Service Manual.
Old Feb 7, 2015 | 07:27 PM
Paul L's Avatar
Paul L
Buckle up your 20lbs of groceries on the passenger seat or the car won't start!! This nuisance device came from the Ralph Nader era of automotive protectionism in the early 1970s and was put in place by an act of Congress for 1974. Basically if you didn't buckle up, or your pet dog on the passenger side did not, the car would not start. Needless to say, public reaction to such a silly device was swift and Congress rescinded the law in early 1975.
If you don't know what that push-button switch is then do not worry. It has been disabled like 99.9% have been.
Old Feb 8, 2015 | 08:47 AM
RETIRE15's Avatar
RETIRE15
Originally Posted by paul 74
buckle up your 20lbs of groceries on the passenger seat or the car won't start!! This nuisance device came from the ralph nader era of automotive protectionism in the early 1970s and was put in place by an act of congress for 1974. Basically if you didn't buckle up, or your pet dog on the passenger side did not, the car would not start. Needless to say, public reaction to such a silly device was swift and congress rescinded the law in early 1975.
thanx paul it looks pretty goofy sitting there ,stix out like a soar thumb .i think i will remove the little housing and tape up the wires.thanx again,this forum is super!!!!!!!!!
Old Feb 8, 2015 | 09:24 AM
Paul L's Avatar
Paul L
FWIW, this pic shows the weight sensor and wiring under the seat. If I remember correctly it was set off by a minimum of 20 lbs. Hence my comment about a pet dog (or a heavy bag of groceries).
Old Feb 8, 2015 | 11:46 AM
my 76 ray's Avatar
my 76 ray
I don't think taping the wires will get you the results you want. You need to close the contacts in the relay. Mine was done by a previous owner by putting a zip tie around the contacts to keep them closed.
I guess you could also connect the wires.
Old Feb 8, 2015 | 12:35 PM
RETIRE15's Avatar
RETIRE15
i just want the engine comp. to look really good ,so i will find a way thanx!
Old Feb 8, 2015 | 12:52 PM
Paul L's Avatar
Paul L
Go to post #10 here:
https://www.corvetteforum.com/forums...o-starter.html
OR:
http://home.comcast.net/~vettfixr/page16.htm
Old Feb 9, 2015 | 03:54 PM
dochorsepower's Avatar
dochorsepower
There's nothing new - all of the old flathead Fords had them. It was a clever thing that allowed you to crank the starter while you were working under the hood. But then that was the days of Fix-Or-Repair-Daily.
To Old push button relay on firewall
