Right sided alternator
Old Feb 15, 2015 | 12:23 PM
dallas121469's Avatar
dallas121469
Default Right sided alternator
Bought a '78 without motor or trans. Have a nice 350/350 combo but I noticed Vette alternators are on the left and the motor I have has the alternator on the right. I assume this is to make room for the AC compressor to go on the right in Vettes. The alternator looks low enough to not cause any clearance issues and I don't mind rewiring the harness. Car was originally an AC car but no compressor was included with the car.
And i won't be putting AC back in the car.
Is it safe to asssume that this will swap in easily?
Thanks.
Old Feb 15, 2015 | 12:33 PM
7T1vette's Avatar
7T1vette
The primary reason the alt is on the left side in C3's is because the horn relay...and all the power wiring for the engine compartment...is on the left fender. Thus, running wiring from the alternator was shorter--and reduced cost (a few cents).
As long as you don't mind running the extra wire, it makes no difference which side it's on.
Old Feb 15, 2015 | 07:32 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
FWIW I moved the alternator over to the right side to get some weight off the LF corner. I just got a partial alternator harness off a junk car (for convenience so that the connector would plug right in), and altered the other end of the harness so that it would plug right into the original alternator harness connector (as I didn't want to cut up a perfectly good portion of the harness).
Chances are the alternator placement "issue" isn't going to be that big of a deal in the grand scheme of things.
Old Feb 15, 2015 | 07:49 PM
briankeery's Avatar
briankeery
The engine you are planning to use will have a long water pump, and the corresponding bracket for the alternator. If you are going to use electric fans, this shouldn't be an issue. If however you are going to be using stock cooling components, the water pump currently on that engine may present a problem.
Old Feb 15, 2015 | 08:39 PM
dallas121469
Default Tips
Thanks for the tips. I have an electric fan setup I will be using so water pump wont be an issue. Has a march serpentine pulley setup so really didn't want to have to change anything.
My only other question is..........Will I be able to use a stock corvette drive shaft with the long shaft TH350 that I have?
Old Feb 15, 2015 | 10:05 PM
TimAT's Avatar
TimAT
The TH 350 had 3 different output shafts- really short for 4x4's, one the tail housing is about 8 inches long and one the tail housing is around 18". the 8" one is the one you want
To Right sided alternator
