Ignition sheild?
Old Feb 17, 2015 | 06:27 PM
Factor's Avatar
Factor
Default Ignition sheild?
Hi all!
finishing up my build and will be putting in a decent radio...does C3 require the ignition shield to be able to have NON interference with the radio frequency?
i am running thick 8.5mm MSD super conductor wires and ready-to-run distributor and SUPER coil block.
ALSO found a hi-power amped hidden antenna...for under passenger side dash....
debating if I need that shield.....
please some feedback...
thanks,
R
Old Feb 17, 2015 | 06:28 PM
Factor's Avatar
Factor
Default Gas tank Overflow hose...
Hi all!,
apparently mine slipped off...any ideas on how to reattach without dropping the tank??
thanks,
R
Old Feb 18, 2015 | 04:05 PM
MelWff's Avatar
MelWff
the shielding is needed for AM reception, have no shielding and running spiral core wires. So you can see the old hose or it disappeared? With gas tank door removed you cannt see point to connect it to ?
Old Feb 19, 2015 | 07:33 AM
Revi's Avatar
Revi
Originally Posted by Factor
Hi all!,
thanks,
R
Open the gas door, remove the fuel cap, remove the black rubber donut, you'll be able to feed the drain line up from under the car and attach it to the nipple on the donut. Use a zip tie to hold it on.
Old Feb 19, 2015 | 10:55 AM
Factor's Avatar
Factor
GOT IT! thanks!
ANY Thoughts on Ignition shields?
never heard for AM only...
R
Old Feb 19, 2015 | 11:13 AM
Revi's Avatar
Revi
GOT IT! thanks!
R
Wouldn't it be easier to just finish the car, drive it around with the radio on and see if you get any static. If not, you're done.
If you get some static you can always add the ignition shielding afterwards.
Old Feb 19, 2015 | 08:32 PM
Cavu2u's Avatar
Cavu2u
GOT IT! thanks!
R
Factor,
After trying shields, RF filters, and different plug wires, the ONLY way I got rid of the radio static in my '73 was changing from Delco to Splitfire spark plugs. I was amazed.
Steve
Old Feb 20, 2015 | 01:14 AM
dugsgms74's Avatar
dugsgms74
When I first got my car (68 427)it had a MSD 6AL set up with thick taylor wires, could hear a faint high pitched whine in the factory radio when on. Later switched back to the stock ignition setup with lectric limited braided wires and added the shielding and the whine went away.
Old Feb 20, 2015 | 12:55 PM
Factor's Avatar
Factor
Thanks guys!
Yes...finishing it is my intention, but want to be ahead of things as some of these are backordered...
THANKS!!!
R
To Ignition sheild?
