Power Steering hoses
Old Mar 8, 2015 | 09:28 PM
eomfdvette's Avatar
eomfdvette
5th Gear
Default Power Steering hoses
I need to replace an hose in my 1978, and I was going to replace them all with braided stainless steel hoses. I found some for $200 but was thing of making my own to cut cost, but I am unsure about the hassle. Any thoughts?
Old Mar 8, 2015 | 10:19 PM
dugsgms74's Avatar
dugsgms74
Im fairly sure that any assemble yourself braided hose(AN style) isnt rated for power steering use. I have made my own power steering hoses in the past but the hose is blue fabric covered and uses specific ends. If you have a hose supply place around you(place that makes hydraulic hoses for industrial use) they should be able to handle the job for a fair price.
Old Mar 8, 2015 | 10:24 PM
509 rat's Avatar
509 rat
thats the way to go having a company that makes high pressure hoses and fitting, thats what I did on my borgeson box, not so bulky now.
Old Mar 9, 2015 | 03:43 AM
hugie82's Avatar
hugie82
The PS lines on our cars have tight bends and a very specific design to work around everything in that tight area. The line kits aren't that expensive and I can't see having them built will save much cash. If you need that extra durability of a stainless steel braided line, then you can bring your old lines to any hydraulic line shop to have them copied but it won't be cheap.
Old Mar 9, 2015 | 11:39 AM
eomfdvette's Avatar
eomfdvette
5th Gear
Thank you for all the advice. I was concerned about the pressure rating and making my own hoses.
Old Mar 9, 2015 | 12:01 PM
Ironcross's Avatar
Ironcross
A major auto parts warehouse, {NAPA maybe} will have OE styles of hoses.......I don't think you will be able to bend hose to fit the PS correctly........
Old Mar 10, 2015 | 01:07 AM
Garys 68's Avatar
Garys 68
Really bad idea. A $15 OEM hose will fit better, be reliable at the 1000+psi working pressure, wont require adapter fittings, and cost A LOT less.
Old Mar 10, 2015 | 05:01 AM
Rotonda's Avatar
Rotonda
You CAN do it yourself BUT you need to use Teflon lined braided hose and associated steel AN fittings and adapters.
The Teflon hose is high pressure and is what is used for braided brake lines. Aluminum fittings and adapters do not provide enough strength for this application - they must be steel. Most of the bigger hot rod catalogues list this stuff.
Old Mar 10, 2015 | 01:35 PM
eomfdvette's Avatar
eomfdvette
5th Gear
What about just getting the OEM hoses and putting my own braided stainless steel covers on them? I think this would give me the look I want, the durability I want, at a price I can stand.
Old Mar 11, 2015 | 08:03 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
As far as I can tell, the "covers" are pretty close to the OD of the hose, and the "pressure" line, of a P/S system, already has fitting on both ends, so you won't be able to slip the cover over them. On the "return" side, there's a fitting on one end, but the other just slips on, and is held by a hose clamp, so you might be able to use the covering on that one.
Old Mar 11, 2015 | 04:13 PM
7T1vette's Avatar
7T1vette
The stock hoses will last for 15 or more years with no problems. And, when dirty you can wipe them down with a rag. If you go with braided hoses, they will be WAY MORE expensive, and you'll have to pull out the pressure washer to get the dirt/grease out of the braiding.
SS braided hoses sounds good, but it might not be as good as you think.
To Power Steering hoses
