I replaced the originals with aftermarket about 12 years ago as the pressed board panels had disintegrated.
Well now the plastic back of the aftermarket panels have begun to crack, the panels never really fit the doors as snug as well as originals either. Before I purchase another aftermarket pair, has anyone made or had built a custom set of door panels? I currently have deluxe panels and would be very interested in hearing from anyone that has had a custom set built/made. Would also be interested in hearing from anyone that has recently purchased aftermarket panels, such as who you purchased them from, how the installation went, and how they fit.
The last set I installed on I got form Corvette America...and they fit just fine. They do take some time to get fitted well and set correctly in place. They are not just going to fall onto the car and be perfect. For me it is making sure they go all the way down at the top and are not hanging up to high where I can see that they are higher than the outer window sealing strip/trim and door edge where your arm would lay on if the window were down.
Then the NEXT trick is making it so the door panel can be fastened with the screws at the top and NOT damaging the vinyl and pulling through the door panel over time. I do not like the 'pucker in' effect at these two top screws.
No need to make Al Knoch makes the original press board backings. In talking with Al a few weeks ago he mentioned he had over 300 sets. Also told me he used to supply GM and has the correct molds. Good Luck
r
and those original molds are why my al knoch panels I bought in 80s fit like garbage and are too thick??? my opinion is he makes top notch seat stuff but wouldn't buy door panels from him and just a note he refused to make right the panels I bought from him.
DUB
I got mine from there as well. I understand they will not be a perfect fit but the major problem was they were bowed at the bottom so they never really secured with the plastic velcro tabs. I tried heating up the plastic panel to straighten, tried clamps, and neither worked. Also struggled with the two screw holes as well.
Okay good to know so who makes good original panels.
Hi 72V & r,
My comments are based on 1970+ AK panels. I've never looked in detail at his 68 and 69 panels so don't know how accurate (original) they are.
It depends what you mean by "original".
As far as I know AK is the only source of the pressed board backing in a newly made panel, everyone else uses black ABS.
The 'skins' that AK applies to his pressed board panels are the same as used on his 'regular' panels and so are close but easily detectable as being a bit different than the originals. There is a problem with the appearance of the 'inlay' area of the panel whether the panel is for a standard interior or the deluxe interior.
I find even my original door panels are difficult to install properly…. having the upper flange of the panel top clipped over the tabs in the door frame and the bottom tight enough that the velcro type fasteners can grab and hold the panels is tough to achieve.
At this point I think door panels fall into the same pit as 1970+ rocker trim…. there is no accurate looking and properly fitting reproduction part.
Regards,
Alan
Hi 72V & r,
Regards,
Alan
Hi Alan and thank you for that information. I just might have to use my original donor panels with crank windows and forget the power window option if I want pure original.
r
I carry both panels, have very few issues out of either one...
CA re-tooled the panels a few years back and they seem to fit just as good as AK panels.
AK panels are now available with the fiberboard backing but it's 300.00 more per set to do this and honestly, I'd rather have the ABS backing (it will last longer than fiberboard).
On our site, retail side panels are Ca, and the forum special section panels are now AK.
Hi W,
I've not seen the AK pressed-board backed panels.
Have you?
If you have, disregarding the longevity issue, what do you think of them?
I'm afraid for me the ABS backed panel just isn't an option.
Thanks!
Regards,
Alan
Alan- It is something we just added to the website... to be honest, I've never seen them but I talked with Al last week about them and he say's they are on the money. I have the link on the site, but I'm just a little apprehensive to turn it on until I do see one.
I purchased my door panels from Willcox (CA box) in October 2012 and they fit very well.
I did not install the top front and rear screws for the reason Dub mentioned and they are still flush all the way around.
Hi E,
I feel pretty confident about the backing, it's the imprint detail in the skin used that concerns me!
I hear about these panels but haven't seen one that was identified as one.
Regards,
Alan
FWIW, I also used Corvette America replacement door panels (the black ABS type) when I restored my car, and they fit just fine. I have no explanation why some fit and others don't!
Hi 72V & r,
Regards,
Alan
Thanks Alan
I'm thinking I might take my current panels and form sheet metal backing versus the press board or ABS Plastic and either buy the delux trim or re-use from current panels. Won't be original but I believe I can get them to fit better without the screw holes at the top of front and rear plus will be able to get bottom tabs to line up.
I don't install those screws unless the car is being judged..
I've not had any issue installing either panel from both vendors. Mid year panels would be a different story though..
With the ABS plastic having a bow in it... I get the top set and install the screws and do my trick to them so they do not compress and damage the vinyl BUT allows the door panel to get pulled tight to the door frame.
Then I install the special clips and install the screws and get the bottom fasteners at the front and back of the door secure...THAT'S IT!
Once the the interior has gotten hot enough the door panel begins to flatten out and I do not worry about the Velcro...because the door panel is tight to the door frame and I feel it is pointless and they are not doing anything at all anyway.
Obviously...if you wan tot make your own door panels....you can and I hope they come out to your satisfaction.
