wiring wows
Old Mar 14, 2015 | 05:08 PM
patrick68's Avatar
patrick68
Default wiring wows
O.K, installed the radio and trying to rout speaker wires. I was pulling on the old left speaker wire and all of a sudden I see this 14 gauge wire with a pigtail hanging down. It's orange and has two connectors at one end. I'm guessing the other end goes into a harness.
Anyone. I'm thinking it came from the fuse box.
Old Mar 14, 2015 | 05:59 PM
DUB's Avatar
DUB
You have to post good photos...and not so much of a close up of the end of the connector which is important and needed...but a photo further away so we can see where the wires are located.
DUB
Old Mar 15, 2015 | 02:01 PM
7T1vette's Avatar
7T1vette
It's always better to trace a wire's route before you pull on it...
Old Mar 15, 2015 | 08:29 PM
patrick68's Avatar
patrick68
Default wiring wows
Have you ever tried to look under a c3 dashboard? nearly impossible without taking the dash apart, I had my fill just getting the clock and radio out! You also need to be flexible like Gumby, I am not.
I tried to chase the mystery wire with my hand, definitely couldn't see the other end. I assume it goes into one of many of the harnesses behid the dash.
Old Mar 15, 2015 | 08:37 PM
Brother Rob's Avatar
Brother Rob
Courtesy light?
Old Mar 16, 2015 | 11:48 AM
patrick68's Avatar
patrick68
DUB
I have posted a picture of the wire. Can't get a picture of the underside of the dash.
Old Mar 16, 2015 | 06:50 PM
DUB's Avatar
DUB
Thanks for the photo.
NO...it is not the courtesy light.
YES..I know all about getting under the dash of a C3...I do it often.
NOW...keep in mind you have to post photos so there is NO MISTAKE on what I am looking at...so putting a white piece of pare behind the back connectors so they do not blend in with you carpet., I need to see the sides and connector ends of this pigtail assembly.
From what I can tell....the color of the wire is TAN...and I bet the end with the two wires coming off of it goes into your fuse panel for an accessory.
What year is your Corvette???
DUB
Old Mar 17, 2015 | 01:53 PM
patrick68's Avatar
patrick68
Default wiring wows
here are the pics of the wire.
Old Mar 17, 2015 | 01:57 PM
patrick68's Avatar
patrick68
Default wiring wows
DUB, it's a 68' convertible w/o A/C. has power windows.
Old Mar 17, 2015 | 04:02 PM
Syl1953's Avatar
Syl1953
Appears to be the alarm wire, on my 70 it hooks to the fuse box, right,upper marked bat.? I have been chasing my alarm system wiring, recently got a Dr. Rebuild wiring diagram for mine. A very easy,concise, diagram. Does your alarm work.? On mine, power goes from fuse box directly to key lock at back. I do not know if the two years are similar.
Old Mar 17, 2015 | 05:33 PM
DUB's Avatar
DUB
THANKS...that is what I needed...PERFECT PHOTOS!!!!
Being a 1968...the terminal you are holding in the first photo in POST#8 will go into the center area of your fuse panel. By the way that it is shaped with the raised notch on one side...it will fit CORRECTLY in only ONE of the three ports you have in the center of your fuse panel. More than likely IGN terminal port....because I doubt it will be the BATT terminal...or the ACC terminal.
I will have to look at the wiring diagram...which I was looking at today oddly enough...so it I feel is your power windows.
Your car may not have an alarm due to it was an option and if your did have an alarm...there would be a lock cylinder in the rear body above your 'CORVETTE" letters.
DUB
Old Mar 17, 2015 | 08:26 PM
patrick68's Avatar
patrick68
Default wiring wows
DUB
No alarm. I didn't understand the bit about the power windows. pleas clarify.
Old Mar 18, 2015 | 07:18 PM
DUB's Avatar
DUB
Do your power windows work with this wire NOT connected and dangling down like you had shown in a photo or two???
IF your power windows DO NOT WORK.
THEN....you take the connector you took a photo of and posted fist in POST #8...and you plug it into the port in the center of your fuse panel...which will be a port that is in between your fuses. You have one vertical row of fuses on the left...and one vertical row on the right...and between these two rows are ports where you can plug a single wire connector. These ports are made in such a way that you can not put the one you have in one that is not tooled and made so the raised notch on the terminable will go into the fuse panel. Simple as that.
AND...just because you plug it in does not necessarily amen your windows work...BECAUSE the terminal is protected by one of the fuses right beside it...either to the left or right...and that fuse may be blown. So have you key on and check the voltage at the terminal your plan on plugging it into.
DUB
Old Mar 19, 2015 | 08:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Patrick; the 68 assembly instruction manual (AIM), power windows option section, shows how the plug up connects to the fuse panel as Dub describes.
Old Mar 20, 2015 | 12:28 PM
patrick68's Avatar
patrick68
Default Thank you
Thank you all for your ideas and suggestions. Your awesome.
To wiring wows
