Engine Bay Wiring Replacement . . .
Old Mar 16, 2015 | 03:26 PM
'76stingraycolorado's Avatar
'76stingraycolorado
Default Engine Bay Wiring Replacement . . .
Hello,
I'm getting ready to pull the engine in my '76. While it's out, I'd like to replace all the old wiring.
It looks like there are two main harnesses: The engine harness that connects to the starter and the "Forward Lighting" harness. If I purchase these two from Lecro-Limited, will this basically cover everything that I need?
Thanks!
Old Mar 16, 2015 | 03:57 PM
Condo_454C3's Avatar
Condo_454C3
That will take care of everything from the firewall forward, yes
Old Mar 16, 2015 | 08:06 PM
Swiftrider08's Avatar
Swiftrider08
Does the car have a/c? If so, that's another harness on the passenger side of the engine compartment.
Old Mar 17, 2015 | 12:33 PM
Condo_454C3
Is that different in 76? It is included in my engine harness on my 74
Old Mar 17, 2015 | 09:47 PM
riverracer au's Avatar
riverracer au
The AC was a separate harness on my '72.
And it's a pain to replace,
had to pull dash and center console apart to get to the grommets on the firewall to run the wires around heater box.
Old Mar 19, 2015 | 08:57 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: order an assembly instruction manual (AIM) when you order your harnesses. The AIM will show how to install them and where they plug up.
To Engine Bay Wiring Replacement . . .
