WATCH your tires!!
Gone are the days of just measuring your tire tread with a penny to see if you need to replace them. Now you need to know your tires’ birthday too! Because research indicates that tires more than six years old should be retired, regardless of their tread depth or their miles on the road.
Here’s why:
As tires age and are exposed to heat, the rubber deteriorates. That’s because rubber absorbs oxygen, which causes what is called thermo-oxidative aging. Sean Kane, president of Safety Research & Strategies, Inc., an organization that researches and analyses motor vehicle issues, gives us an everyday point of comparison:
“If you take a rubber band that’s been sitting around a long time and stretch it, you will start to see cracks in the rubber.”
Research over the past 30 years, and even earlier, raised questions about the safety risks of aging tires, but the rubber industry and automakers were slow to share this information with lawmakers or consumers.
In 1985, tire manufacturer Uniroyal first publicly shared its concerns about the tire safety of newly introduced radial tires, which were advertised to last much longer than old style tire models.
The national uproar over Ford Explorer rollovers in the early 1990s focused on SUV stability standards, but failed to note that tires older than six years experienced tread separation that, at highway speeds, contributed to lethal accidents.
In 2002, the National Highway Traffic Safety Administration (NHTSA) proposed an aging test for tires, but opposition from the rubber and auto industries was so powerful that the proposal went nowhere.
Five years later, in 2007, NHTSA delivered a Research Report to Congress on Tire Aging, with the results of a study of tire-related auto insurance claims between 2002 and 2006. This research indicated that 77% of tire-related claims came from five hot-climate states, and 84% were based on tires more than six years old.
Finally, in 2008, NHTSA issued a consumer advisory urging motor vehicle owners to check with manufacturers about tire aging to see what they recommended. Car safety advocates continue to call for actual regulations about tire age, but to date none have surfaced.
- See more at: http://www.searcylaw.com/do-you-know....Zi8aXkCl.dpuf
1. Different manufacturers make differing quality tires based on materials and construction techniques-A Michelin tire (premium manufacturer) is going to be very different than a Chinese tire, even if its the same type tire with similar speed ratings
2. Speed Ratings Matter: Most people think that I don't need a Z rated (above 149 MPH rating, Y sub rating-186 MPH) tire because I don't drive anywhere near the aforementioned speeds. The fact is and the driving force behind the decision that every tire I own for every car-new and old-have a ZR rated tire is because these tires have a MUCH STRONGER construction than a crap S rated tire (112 MPH)-A Michelin Pilot Super Sport ZR (W/Y sub rating) is in a different universe from say a BFG Radial TA S rated tire-no contest! I am not referring to racing either-just normal street/highway driving.
3. Proper Tire Inflation-Again, the fact is whether the tire is 8 years old or 3 years old, under inflation will make a tire run MUCH HOTTER than with inflation of 30-35+. Tire inflation is just as important in cold weather as hot since tire inflation naturally drops with cold temps-reason you see many tire blowouts if the temperature drops low quickly from one day to the next. Result: tire blow outs at highway speeds. A high speed rated tire will resist this tendency much more than a low speed rated tire since the higher speed rated tire is designed to run much hotter at very high speeds. Improper tire inflation is probably the #1 factor in tire blowouts..
4. Visual Inspection: Rather than depend on the date of birth of the tire, make it a habit to look for cracks in the tread and especially the sidewalls of the rubber compound…Any cracks in the sidewall area necessitates replacement, regardless of age….I have seen cracks in very young tires and zero cracks in older tires-See why the manufacturing date does not tell the whole story?
5. Ultraviolet Sun light exposure-Probably one of the biggest reasons the rubber in tires deteriorates at varying degrees depending on exposure. If the tire lives in the desert or desert like conditions 24 hours a day, every day, the rubber will deteriorate much faster than ones in cooler climates, covered in a garage, most of the time. My 78 L-82 has 255/45/17 ZR's that spend 99.9% of the time in the garage under a car cover-tires look perfect after 7 years…no need to replace-will probably go 10 years with these tires, maybe more based on the visual inspection. Example #2: 2001 Pontiac Grand Prix currently has Goodyear Ultra Grip V rated Snow tires (Many State Police Agencies use this winter tire) with a build date of 2002-no cracks anywhere, rubber though is getting harder-will replace after this winter-Driven less than 4,000 miles per winter per year, covered in the garage for 9 months every year.
6. Real World Operation: I have experienced 2 sets of tires over the many years where the visual inspection indicated replacement AND the tire was exhibiting poor braking performance under moderate to hard braking on a dry surface-the front or rear tires would LOCK prematurely from the hardening of the rubber tread from age/climate exposure which was never experienced before. Time to replace ASAP.
I applaud the lack of legislation mandating replacement of tires after X number of years since the issue really is more about many factors than one DOB number. The last thing most of us need is the government trying to protect us from ourselves with more rules/laws and universal planned obselenscence for every tire -no thanks .Just another viewpoint.
When I got my BF Goodrich tires about a year ago, I told the salesperson that I wanted the tires made in 2014 and I wanted to see, on the tire, the code (date). They were all 2014 tires.
I have had a sidewall blow out on a modern tubeless tire and it was pretty dramatic. Major bang (gunshot?) then it got a little squirlly. Luckily, I was going about 40 down a straight road. The tires were a major brand, good quality tires. The other 3 looked good, but the company replaced all 4 because they were 6+yrs old. So, it can happen.
I recently replace my c3 tires that were 8 yrs old that had about 30% tread wear left and xlnt looking sidewalls. I feel a lot safer on the local mountain roads.
I was finally able to take it on a test drive....all four tires looked good/had minimal wear......NO PROBLEM.
Then at 60++ mph the front end began shaking badly after putting 50 miles on the car.
The front great-looking tires were literally coming apart with huge bulges in the tread.
I drove home about 5 miles at 25 mph.....and didn't drive the car again until new tires were on it.
It could have been a totaled project........or worse!
didn't think at the time to take a photo of the tyre.
prompted me to look at my tyre dates.
2 were around 15yrs and the other 2 were even older.
and my car has been downunder since august 2006, so they old before it left you guys
Btw-scary stories of tire blowouts. Fact is the number of tire blowouts for newer tires are extensive as well. Check your tires, proper inflation 30-35+ psi regardless of psi on car sill, high speed rating...minimum of V, prefer Z rated tires-if you have 15 inch rims you are pretty much limited to S/T rated tires...change those much more often..
Better that it happened in the tire shop than on the road ...
Last thing we need is our corrupt, lying, moron government sticking there nose into anything.
course it sat in a garage, door down most of those decades....but still never an issuellll house faced east garage on south side....even the paint fades on the car in spots because of the garage window....but not the tires, never gave then a second thought....
I think it's crap construction, along with everything else these daze.....
Will install the Mastercraft (Cooper) Avenger GT's in their place (P255-60R15).
