Headlight will only go down when engine off
Old Mar 23, 2015 | 07:19 AM
skilew's Avatar
skilew
Default Headlight will only go down when engine off
Ok here is another question on vacuum issues with headlights. I didn't see this exact problem on headlight actuation. If its there please point me in the right direction.
My headlights on my 71 Vette come on just fine but my right light will not go down until I cut the engine off. Any suggestions will be greatly appreciated. Thanks.
Old Mar 23, 2015 | 09:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the vacuum relay valve on the right side.
Old Mar 23, 2015 | 09:58 AM
skilew's Avatar
skilew
Check the relay how? Also if it takes vacuum to open and vacuum to close the headlight, it seems that with the engine off (no vacuum) how would it close?
Old Mar 23, 2015 | 10:08 AM
Peterbuilt's Avatar
Peterbuilt
Here's how to test each component.
http://www.corvette-101.com/vacuum.htm
What year is you car?
Old Mar 23, 2015 | 11:30 AM
skilew's Avatar
skilew
My Vette is a 71.
Old Mar 23, 2015 | 11:53 AM
Alan 71's Avatar
Alan 71
Hi S,
There are 2 relays mounted to the underside of the hood surround between the head lights.
Reverse the hoses running from the relays to the headlights, (large green and red hoses), so the left side relay is now controlling the right side headlight, and visa-versa.
If the problem switches to the left headlight you'll know there's a problem with the right side relay.
Then you can test the operation of the faulty relay with a vacuum pump/gauge like a mityvac.
Good Luck!
Regards,
Alan
The location of the relays and the large green and red hoses. The horn is partially blocking the view of the left side relay.
Old Mar 23, 2015 | 12:22 PM
skilew's Avatar
skilew
Originally Posted by Alan 71
Hi S,
Good Luck!
Regards,
Alan
Are the existing hoses long enough to be able to swap between the two relays?
Old Mar 23, 2015 | 03:07 PM
Alan 71's Avatar
Alan 71
Hi S,
I believe so.
If not unscrew the relays from their mount plate so they'll just hanging and can be pulled to the side.
The alternative is to test the relay in place.
Do you have a mity-vac?
Regards,
Alan
Old Mar 23, 2015 | 06:53 PM
skilew's Avatar
skilew
I do have a mity-vac.
Old Mar 23, 2015 | 08:29 PM
Dave J's Avatar
Dave J
The relay has a piston inside it's bore that is raised and lowered by the control chamber on top. If the rubber piston is leaking around the seal, you will have a vacuum leak. The leak could be minor or completely blown. Any leak will cause problems.
Simple quick way to test the relay is to connect your hand held vacuum pump to the middle port, and block the lower port with your finger or a short section of blocked vacuum hose. Pump it up and the relay should hold vacuum and not leak over time.
Old Mar 24, 2015 | 12:12 PM
skilew's Avatar
skilew
I think I found my problem by discovering another problem. My wiper door has not work for some time. I believe it is the "witch hat" actuator. Last night I plugged both lines feeding the actuator trying to trouble shoot that problem and then I just decided to recheck my headlight issue and they both worked perfectly. The loss of vacuum through the wiper acuator must have been affecting my headlight actuation or for some other reason my haedlights are now working.
Old Mar 24, 2015 | 03:26 PM
Alan 71's Avatar
Alan 71
Hi s,
Maybe?
The large hose supply for the headlight and wiper door actuators are interconnected by a 'T' in the yellow striped hose very near the vacuum reserve tank.
So could be!
Regards,
Alan
Old Mar 25, 2015 | 07:12 AM
skilew's Avatar
skilew
Hi s,
Maybe?
So could be!
Regards,
Alan
Thanks, I will check that this weekend.
Old Apr 3, 2015 | 12:22 PM
skilew's Avatar
skilew
Just wanted to give an update. Headlights are now fixed due to fixing a vacuum leak from the wiper door actuator.
To Headlight will only go down when engine off
