Power Steering Pump
So far I have not been able to separate the 2 parts, and I wonder if the flat area is the reason
The flat area may give you a little bit of trouble. I have stopped wasting my time on pumps...because if they leak...the time I spent was wasted and for me doing this all the time...I do not have time doing things twice or three times. UNLESS the owner wants the original....then they pay for however long it takes me to restore their pump.
It is slow process to begin by securing the cast section of the pump without damaging anything and then I try to rotate the reservoir a little and slowly work it off.
DUB
DUB
I think you're right. Probably better to use as a core and not have to worry about the flat spot causing a problem.
I'll probably take it to spring Carlisle and trade it in.
You should able to rework/bend it, then pull the 2 pieces apart. If I remember right, there is a o ring seal behind that lip.
Give it a try, and if it doesn't look real good, trade it in.
