Q jet problem
Old Apr 4, 2015 | 12:22 PM
mystingray1's Avatar
mystingray1
Default Q jet problem
why would my q jet squirt from the jets connected to the accelerator pump on their own without me pumping the gas while the car is not running and it is warm? it is creating a flooded situation and is not fun
Old Apr 4, 2015 | 12:27 PM
mikem350's Avatar
mikem350
Sounds like fuel boiling in the carb (percolation). Search the archives, this is a chronic problem with todays ethanol fuels.
Old Apr 4, 2015 | 12:39 PM
mystingray1
Wow is there a cure for this?
Old Apr 4, 2015 | 02:28 PM
lars's Avatar
lars
It's rare for the Q-Jet to have this problem - this is usually a Holley issue with the bowls that hang out over the manifold. The problem can be corrected on both Q-Jets and Holleys by using a reflective heat shield between the carb and the manifold.
This assumes that you are using the correct gasket between the manifold and the carb - you didn't state what year your car is. If you have the early-style intake with the "smiley-face" exhaust crossover, you have to use a special 3-piece gasket set to prevent the hot exhaust gasses from boiling the fuel in the carb.
Lars
Old Apr 4, 2015 | 02:46 PM
mystingray1
Thanks, my car is a 81 with 319,000 on the clock, this is a daily driver and i have been running this carb for the last 7-8 years with no problem always using Chevron Mid Grade, so i am not sure why all of a sudden this has become a problem, if just replacing the gaskets is the answer that would be great?? I pulled the aluminum manifold off a long time ago when i stripped the threads have been running cast iron for about 15 years now
Old Apr 5, 2015 | 01:03 AM
7T1vette's Avatar
7T1vette
Might be due to the amount of ethanol is being put in your fuel now. Refineries can vary the amount based on time of year and production costs. Sure sounds like a fuel 'perk' problem. The cast iron manifold would also hold more heat than the aluminum unit.
Old Apr 5, 2015 | 01:37 AM
mystingray1
I can't imagine that they have added that much ethanol as of late, this seemed to come on quickly, I have been running a heavy amount of carb cleaner and it seemed better today, just odd as this has never been a problem before
Old Apr 5, 2015 | 09:47 AM
74modified's Avatar
74modified
Spring is a good time for percolation. Fuels are blended differently for cold weather, and a tank of winter fuel plus warm weather can be a cause. If you are adding "stuff" to the fuel to clean the carb, you may be adding to the problem. Not sure of your exhaust or intake, but the exhaust crossover, and/or heat riser valve could also help overheat the fuel.
Old Apr 5, 2015 | 11:50 AM
mystingray1
Thanks, so it doesn't sound like this is an issue of the carb needing to be rebuilt?
Old Apr 5, 2015 | 11:51 AM
mystingray1
As I have never seen this issue before?
Old Apr 5, 2015 | 12:45 PM
74modified's Avatar
74modified
If what you say is happening, it doesn't sound like you need to rebuild. It sounds like the fuel is boiling. This could be the result of several different things - or a combination of things. But dont take my word, you had Lars above giving you some information, and he is the exalted guru of the Qjet. The shield he mentioned was in the link I put in you other general thread.
Old Apr 5, 2015 | 01:01 PM
mystingray1
Thanks, I just find it interesting that this has never been a problem until now
Old Apr 5, 2015 | 01:03 PM
lars's Avatar
lars
Your problem is not normal. The fact that the carb was running without this issue, and it suddenly started doing this, is indicative that something has happened. Normally, when a Q-Jet boils the fuel in the bowl, the fuel will bubble out of the main discharge nozzles and dribble out of the transition slots. I've never seen a Q-Jet discharge fuel from the accel pump discharge nozzles when hot - that's a unique Holley problem. If I were you, I'd pop the top off the carb, replace the float with a new NitroFill float (NAPA part number 2-442), set the float level to .300", and then pull the accel pump out of the bore, make sure it's good, and remove and check the accel pump check ball to make sure it's not jammed in its seat. Finally, check your base gasket and make sure that the manifold you're using does not have any way to expose the bottom of the carb to any hot exhaust gasses from the exhaust crossover. If you have an EGR manifold, make sure things are working correctly and that hot exhaust is not bleeding into the intake under the carb after shutdown.
Lars
Old Apr 5, 2015 | 01:34 PM
mystingray1
Thanks for the input Lars, hopefully this will correct itself else I will have to look into your suggestions above or try my hand at rebuilding the original carb I pulled off, hopefully someday soon I will be bolting down the FIRST TPI injection unit that has been on the shelf for the last 10 years
Old Apr 5, 2015 | 04:51 PM
PAmotorman's Avatar
PAmotorman
Rochester came out with a very light spring part #17083343 to put on top of the pump ball check valve that may solve your problem
Old Apr 5, 2015 | 04:56 PM
mystingray1
Thanks, so would this stop percolating pressure from purging from accelerator jets and is this a fairly easy fix?
Old Apr 5, 2015 | 05:13 PM
PAmotorman's Avatar
PAmotorman
you have to take off the carb top and remove the float to get to where it goes on top of the check valve ball bearing. it puts more pressure on the check ball bearing to hold it in place
To Q jet problem
Old Apr 5, 2015 | 05:25 PM
mystingray1
Thanks, and this would stop the purging through the accl pump squirters?
Old Apr 5, 2015 | 05:36 PM
PAmotorman's Avatar
PAmotorman
I can not say for sure but it will take more pressure to open the check ball
Old Apr 5, 2015 | 05:59 PM
mystingray1
Thanks, I may have to give this a try if the problem continues
