Borgeson install, 454 w/ headers
I'm not going to repeat stuff that was already posted in the last Borgeson thread here:
https://www.corvetteforum.com/forums...n-install.html
My car is a '71 with factory LS5, PS, PB, AC. I have Edelbrock aluminum heads with stock exhaust port locations. Headers are Hooker Supercomps, 1 7/8" primaries (under-car, not sidepipe).
I removed the stock box and installed the Borgeson from the top. I had to remove the master cylinder from the booster, but kept the lines attached. Also removed the bolt holding the distribution block bracket to the frame so I could move the master more. It's very tight to get the box in between the valve and master.
Instructions say 68-72 has to relocate the brake lines. I did not have to do that. Distribution block is still in the factory location and I'm using stock lines.
The brass adapters that go in the box to adapt from o-ring to flare are funky. One side just fell into place, the other was press-fit. I screwed up by using a steel punch to drive it in and damaged the adapter. Luckily if you buy the conversion kit you end up with extra adapters as they come with the box as well as the lines. I pulled the damaged one out and found a better way to get the adapter in: Just lay it in the box, attach the hose and let the fitting press it in as you tighten it. Very easy that way.
Clearance from the #3 header pipe to the box is actually greater with the Borgeson than stock. #5 is much tighter. If you have larger primary header and/or raised exhaust ports it will be problematic. A dent in #5 is most likely required.
If anyone needs factory power steering components, I have some for sale... good condition, didn't leak. Steering box recently rebuilt by Tracdogg2.
When I installed mine I found I actually had better clearance everywhere with the Hooker 2-1/8" headers and the .600" raised exhaust ports on the Brodix heads.
I was able to "remove" the dimple I previously needed on the #3 pipe.
With the turbocharger install I used McJack's 2" shorty headers from Corvette Central and they clear everwhere fine even with the raised exhaust ports.
JIM
I also got a Borgeson box and will install it soon.
My car is a 72 454 with Sanderson BB 5 Block- Hugger headers.
There is little space left even with the stock box.
Can anybody report if the Borgeson will clear with Sanderson headers ?
Andreas
Regards from Down Under.
aussiejohn
Has stock 215 heads and 2" primaries (probably too big, but came on the car!)
