1972 fuel tank replacement
Old Apr 8, 2015 | 08:31 AM
riverracer au's Avatar
riverracer au
Default 1972 fuel tank replacement
I have a leak from a bad previous weld repair that was done on my original tank.
It's showing rust pitting inside along the bottom edge as well.
So time to get a new one.
So, what / where are the best tanks to buy?
I've c'n 18 - 20 - 24 gallon sizes advised, I thought it was a 18gallon that was std?
Can you buy a larger capacity size? That would be handy for long trips.
Old Apr 8, 2015 | 01:57 PM
MelWff's Avatar
MelWff
where are you seeing 24 gal tanks that fit a 72 Corvette?
Old Apr 9, 2015 | 12:49 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
I bought mine from Quanta: http://www.gastanks.com/Corvette/products/19/. I recall they advertized higher capacity than stock but after install i found it exactly the same for my '74.
If u want more capacity it will have to be custom.
Old Apr 9, 2015 | 04:17 AM
riverracer au
http://www.ebay.com.au/itm/New-Fuel-...item51a4e9ba2d
Old Apr 9, 2015 | 08:19 AM
Alan 71's Avatar
Alan 71
Hi rau,
The dimensions listed for the tank are the same length, width, and height as the original (18gal).
I'd clarify just what you'd be buying.
Regards,
Alan
Old Apr 9, 2015 | 02:25 PM
MelWff's Avatar
MelWff
the tank is made by a company called Spectra, part number GM33F and all the sites I find list it as 24 gallon but I cannot find the manufacturers site to confirm this.
Old Apr 9, 2015 | 04:04 PM
Alan 71's Avatar
Alan 71
Hi MW,
The dimensions for the tank are listed at the link rrau furnished.
I think Spectra is in Canada.
I may be mistaken but I believe they're the manufacturer of the tanks Quanta sells.
Regards,
Alan
Old Apr 9, 2015 | 09:48 PM
riverracer au
does anyone make a larger capacity tank for a '72 coupe?
i've just got back from a 3000+km(1860mile) trip,
and stopping every 400km(250mile) to fill up gets a bit old after a while...
Old Apr 11, 2015 | 12:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by riverracer au
...does anyone make a larger capacity tank for a '72 coupe?...
Why take the risk? By the time it reaches you in Australia, it may not fit.
Old Apr 11, 2015 | 03:30 PM
briankeery's Avatar
briankeery
The eBay tank has a capacity of 91 litres which equates to 24 US GALLONS. A REAL gallon is equal to 1.2 US gallon. So 91 litres would equate to a 20 gallon tank.
Old Apr 11, 2015 | 06:00 PM
riverracer au
so what you are saying is that it's the same tank, just false advertising?>
looks like it dosen't have the nipples on both sides anyway, which i need. mine was a CA issue car.
there's a supplier down here that has a tank for 360$au + 50$ postage, think i'll go for that.
http://www.ebay.com.au/itm/Corvette-.../281659202507?
To 1972 fuel tank replacement
